Klasse SG easier applied by hand
I have been using a white lake country CCS pad to apply KAIO which has given good results. I follow with a black CCS pad but I find that the Klasse SG seems to disappear so fast that I am adding a lot of product to the pad. If I use a foam pad a little goes a long way.
Will it make a difference in appearance to add the SG by hand? Will the black CCS pad make it look any better?
Re: Klasse SG easier applied by hand
What does the manufacturer recommend? Usually when it comes to using a wax or sealant, the advantage to using a machine is a thin even coat. Some manufacturers specify hand application and some a specific mf applicator.
looks won't be any different, only removal may be better or worse depending how much you put on. Do whichever method is best for you so you apply the SG and thin as possible, therefore making it easier to remove.
By wonderbar in forum Auto Detailing 101
Last Post: 12-05-2016, 10:10 PM
Last Post: 07-22-2014, 06:19 AM
By Randy M in forum Auto Detailing 101
Last Post: 09-05-2012, 10:41 PM
By radarcontact in forum Auto Detailing 101
Last Post: 05-02-2011, 01:42 PM
By KLRPilot in forum Introduce Yourself
Last Post: 06-29-2009, 06:03 PM
