Results 1 to 10 of 10
Thread: Holograms ???
    Dec 2011
    Holograms ???
    Just bought a new car and noticed it has holograms from the dealership. I have some dodo juice lime prime and one of each lake country ccs pads for da polisher. Will that remove the holograms?
    Sent from my DROID BIONIC using Tapatalk
    Super Member RhetoricMixes's Avatar
    Dec 2011
    Brazoria, TX
    1,020
    Re: Holograms ???
    Quote Originally Posted by Hitman0150 View Post
    Im sure the community on here can help you a little better if you posted some pictures of what your describing. Most of us know what a hologram is anyways but pics always help the situation.
    Dec 2011
    I was trying to get a picture. Car is polished metal metallic and i cant seem to get the holograms in picture
    Dec 2011
    Would lime prime work with porter cable and an orange pad?
    Junior Member insigner's Avatar
    Apr 2012
    53
    Re: Holograms ???
    Yes it will and it will most likely remove any hologram you have.
    Make sure you are not referring to Lite Version of lime prime which has no abrasives.
    Dec 2011
    Yes i have the regular lime prime. Just was wondering wich pad was best. Also, should i follow up with a hard and soft dodo?
    Apr 2012
    53
    Re: Holograms ???
    It is Trial and error, usually Polishing Pad should be ok IMHO.
    Lime Prime has very mild abrasives, I recon you won't need 2 step polishing procedure.
    Re: Holograms ???
    Lime Prime with an Orange pad will likely remove the swirls but it also might leave behind what's call DA Haze or Micro-marring.
    Read more about it here,
    The difference between Rotary Buffer Swirls, Cobweb Swirls and Micro-Marring
    Tracers Tracers - RIDS - Pigtails - Cobweb Swirls - Rotary Buffer Swirls - Holograms - Water Spots - Bird Drooping Etchings - Micro-Marring
    See if you can remove the swirls using a polishing pad and before buffing out the entire car do just a Test Spot to one area and make sure you're getting the results you want before buffing out the entire car.
    Sad to say but your story is all to often...
    DISO = The Dealership Installed Swirl Option
    The story of 3 H's - Horrendous, Horror Story and Hack Detailers...
    Dec 2011
    Thanks for input. So maybe i should back off to a green polishing pad?
  10. #10
    Re: Holograms ???
    Possibly.
    "You don't know what you can do until you try"
    Modern clear coat paints are scratch-sensitive, that is they scratch easily. Micro-marring or DA Haze is a type of scratching that is caused by too aggressive of a pad or too aggressive of a product or a combination of both.
    So before settling on a process,
    Process = Pad, Product, Tool and Technique
    Prove your process by doing a Test Spot to a small area and then inspect. Try the least aggressive products to get the job done. Least aggressive products can include buffing pads.
    The Graphic Equalizer Analogy to Polishing Paint
  1. Holograms ?
    By chuckk in forum Auto Detailing 101
    Last Post: 01-03-2016, 05:18 AM
  2. Help with holograms?
    By MstrJosh in forum Auto Detailing 101
    Last Post: 07-25-2015, 12:07 AM
  3. Now that's some holograms
    By Nate3420 in forum Auto Detailing 101
    Last Post: 06-03-2013, 07:08 PM
  4. Holograms!!
    By 93fox in forum Ask your detailing questions!
    Last Post: 02-07-2011, 10:20 AM
  5. Holograms in my BMW X5
    By Goodloe3 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 12-20-2010, 12:38 AM
