Switching to Menzerna...
This is in NO way a hit on Meguiars 105/205. Been using it for a while now. And while it produces phenomenal results with a DA polisher, it's working time with a rotary leaves something to be desired. Which Menzerna polishes should I look in to to replace the 105/205 combo when I'm using my rotary?
Thanks!
Re: Switching to Menzerna...
That's what I was leaning towards as well... Just wanted some input. Thanks!
Id go with Fast Gloss, it's a step above powergloss and finishes down very nice.. I've used it a few times with my da and its almost get away with a 2step..
Fast Gloss (S500) is not available in the states due to the high VOC.
And yes, S500 is a killer and pair it with PO203s and PO106FA and you have a winning team.
I have a few Menz polishes, never needed Powergloss. I use SIP and 85RD.
SIP, nano(PO106FA) and PO85RD are awesome polishes. I also keep power finish around for one step.
Thanks!
i have switched to menzerna super intensive polish and found it cuts much better than megs 105 with a pcxp, especially on hard clear coats. i took the advice that bobby gave you.
I still find the ceramiclear polishes from Menzerna all that !
By Ryan Johnson in forum Wet-Sanding, Cutting & Buffing
Last Post: 12-12-2020, 08:24 AM
Last Post: 05-01-2018, 03:10 AM
Last Post: 06-04-2016, 08:49 PM
By rlmccarty2000 in forum RUPES BigFoot Oribital Polishers
Last Post: 02-09-2015, 10:46 PM
By Ryry11 in forum Auto Detailing 101
Last Post: 07-08-2013, 09:19 PM
