Is it safe to..
Is it safe to have two buckets filled with cold water and Megs APC and every time I am done doing paintwork or washing cars throw my MF towels in there and let it soak till whenever I have enough to wash? That could be a couple of days to a week. Should I buy a lid to put on top?
If it is safe, should I be using APC+ for this or APC, I only have the regular one, albeit I feel like I made a huge mistake not buying the APC+
Is it safe to use distilled white vinegar, EVERY time I wash my MF towels?
Is it safe to use M105 on the whole car, not buff anything off, go over the whole car again with m205 then buff? Or section by section?
Thanks guys
Re: Is it safe to..
I see nothing wrong with it. I used to leave my microfibers in a dawn solution for a week at a time before I washed them.
To the second, no. Remove M105 after each section.
Shawn Tedrow
Tedrow's Mobile Auto Detailing
facebook.com/TedrowsMobileDetailing 845-642-1698
Re: Is it safe to..
Thanks so much Shawn!
So you just soak them with Dawn liquid soap? Sounds very cost effective I may give it a try.
Re: Is it safe to..
I don't think it's a problem, I've done exactly that with APC+ and both DP MF & pad cleaners. You could just use more Microfibers so there is enough to run a small load sooner. You probably shouldn't leave polishing pads soaking for a week though.
Don't worry about the APC vs APC+ too much, the + is just non foaming for use with extractors and has an orange scent.
Re: Is it safe to..
White vinegar solution is a good idea, i chuck them in a bucket till i have enough for a load.
I dont have anything in the bucket but may in the future...
Re: Is it safe to..
Thanks guys
I'm confused?
Are you asking if it is ok to apply 105 (but not remove) and then apply 205 on top of it?
Flash
Re: Is it safe to..
Originally Posted by Flash Gordon
I'm confused?
Flash
Yeah, you know - layering.
Re: Is it safe to..
You guys and your fancy techniques
Re: Is it safe to..
I'm confused?
Flash
exactly! layer the 205 on top then buff off the m105 and m205 at the same time.. seems like the consensus is no because of the crazy drying of m105?
Remove the 105.
Reasons:
It's a pain to wipe off after its been drying for a awhile.
You don't know the true condition of the paint so you are essentially blind buffing.
The dried on 105 could alter the effectiveness of the 205 as well as contaminate your pad
By Vancity808 in forum Auto Detailing 101
Last Post: 12-05-2013, 09:00 PM
By slickooz in forum Auto Detailing 101
Last Post: 01-08-2012, 09:45 AM
Last Post: 04-14-2010, 10:55 AM
By MisterShark in forum Auto Detailing 101
Last Post: 08-21-2009, 10:20 AM
By changaroo in forum Auto Detailing 101
Last Post: 07-09-2009, 10:47 AM
