Page 1 of 9 123456789 LastLast
Results 1 to 10 of 83
    Oct 2010
    66
    What electric pressure washer do you use?
    Any of you guys have a good recommendation for a good electric pressure washer? Looking for one that is reliable and does not leak water like my other one! -_____-
    Mar 2011
    171
    Re: What electric pressure washer do you use?
    I picked up a Cleanforce 1,800 psi 1.6 GPM Axial Cam Electric Heavy-Duty Pressure Washer from homedepot. I have not had any problems with it nor any leaks. I was a little scared of buying it though because of the reviews but if you know how to use it and take car of it, it will last and work great.
    Super Member CleanGene's Avatar
    Nov 2010
    363
    I have two Karchers, both of which are serving me well.
    "Tell Me What I Can't Do, and I'll Show You What I Can Do." ~Eugene
    Newbie Member heynicebits's Avatar
    Apr 2011
    For car detailing size and power aren't too much of an issue. There are some things to take into consideration
    gas/electric - its personal preference at this level
    motor type - induction if choosing electric.
    I would also try to stay away from non-standard tips and guns that come with the really low end machines. They can be problematic if you want to pick up a foam lance later down the road.
    Good luck
    Super Member Marc Hufnagel's Avatar
    Apr 2011
    SW Illinois
    787
    I picked up a 3800 PSI 3.0gpm Cat brand w/ Cat pump. It's 155 lbs and I think I've bit off more than I can chew with it - I can't load it in the truck without a strong helper. Awesome machine w/ Yamaha MZ300 engine, 50ft hose, 5 tips, adjustable pressure. Works awesome though with a foam cannon I got it for almost 50% off at Home Depot due to (2) failed Ridgid units within a week and dealt with the store manager.
    Anyone want to buy it in the Southern Illinois area? No shipping LOL.
    Super Member AeroCleanse's Avatar
    Nov 2008
    Neenah, WI
    2,422
    I picked up a Greenworks (I think) from Lowes. So far so good.
    Oct 2010
    66
    Quote Originally Posted by CleanGene View Post
    And which karcher models are that?
    Oct 2010
    66
    Super Member cutter's Avatar
    Mar 2011
    Clanton, AL
    526
    I use a Karcher gas powered with a Honda 5.5 hp engine...I followed your link and read the reviews a Lowe's and it seems to be a good unit. I think it had one really negative review and they may have just gotten a bad unit to begin with.
    My name is Jeff and I like to make things SHINE!!!
  10. #10
    Regular Member MCA's Avatar
    Mar 2006
    Dallas, TX
    114
    I am extremely happy with my AR North America AR383 pressure washer. I have noticed that the price fluctuates very frequently.
    Amazon - AR383 Link
    Pressure Washers Direct - AR383 Link
    Positives:
    - Solid Build Quality
    - Metal Fittings and Motor
    - Strong Spray Performance - Hard to quantify this as I had a 1600 psi Karcher that lasted 4 years, but the AR383 has a much stronger spray (appears to be much higher than the 300 psi difference between the two washers)
    - Includes a soap cannon - It is advertised as a 'foam cannon' but it shoots out more suds than foam
    Negatives (minor):
    - The lance hose is thin and will kink
    - This is probably true for most pressure washers, but the garden hose inlet is setup as male. You will have to purchase a coupler if you want to use a quick-connect plug. One plastic mini-quick connect plug and adapter comes with the unit but it is not compatible with the high flow brass quick connects that most of us probably use.
  1. Electric pressure washer ?'s
    By ssnobrakes in forum Auto Detailing 101
    Last Post: 06-08-2019, 11:32 PM
  2. Electric Pressure Washer....what PSI to get ?
    By Levithan9 in forum Auto Detailing 101
    Last Post: 03-28-2017, 05:27 AM
  3. Electric Pressure washer
    By Redfireshaker06 in forum Auto Detailing 101
    Last Post: 02-29-2016, 03:20 AM
  4. electric pressure washer?
    By Chad215 in forum Auto Detailing Tools and Accessories
    Last Post: 05-18-2015, 06:36 PM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
