Help, is this normal?
Doing my first car with a DA, a PC. Black SUV. I did my test panel from start to finish. Tried SwirlX first but it didn't achieve the results I was looking for. Switched to Ultimate Compound followed by swirlx and it was looking great. I did the side panels and hood with no problems.
Fast forward to the roof. I did one coat with UC, speed 5, using LC orange pads, just like everywhere else. It looked great on the roof, but to my surprise when finishing, my pad is now dark gray. This never happened anywhere else. Did I cut through all the clear coat somehow? Is it just because the roof has some built up oxidation or something I'm removing. One other alternative, I got lazy and didn't tape the seals and sunroof so my pad was sliding over that too on top. Could the gray be from that?
I just want to make sure I'm not ruining my vehicle on my first attempt. Everything is looking awesome otherwise.
Thanks for the help!
Re: Help, is this normal?
You will know if you've cut through the clear.
Unless you've got single stage paint on the roof, it's most likely from the trim lines.
Pictures would help.
if your using a DA i highly doubt you ate through the clear. What kind of car is it? pictures would help ALOT! post pics and i will guide you from there and so will others!
Thanks for the quick replies, you are right I should have put pictures up but I immediately cleaned the pad for some reason (like wiping down the murder weapon?) If I cut through clear would it still be so shiny?
It is a 2005 Ford Escape.
If it happens again, I will try to post pictures. I moved to a different section of the car entirely for now.
I'm pretty sure it may be from the rubber trim
Do post up the pictures though
Chris (a.k.a. Pockets)
Warehouse Manager
Pockets@poorboysworld.com
(845)215-9700
It wouldn't be as shiny. It's like a "clear film" that glosses it up I guess. You shouldn't worry.
I think its just spent wax
Spent wax? Like the UC or something? I've been cleaning "on the fly" with the terry towel method I saw on here. Or do you mean something different?
Almost gaurantee it's from the trim. Switch pads and don't hit the trim and see if the pad turns black. But this time, tape the trim and re-buff everything you did after you hit the trim because chances are it's swirled. The black you see (if) from the trim is dirt so, it was probaly scratching as you worked.
I will definitely tape it before I hit it again. I put the halogens on it and I don't really see much left. I think I can get by with just the swirlx step and then PO85rd.
In retrospect, pretty silly not to tape the trim up there. I did everything else, it would have taken two more minutes.
As in most things, mistakes happen when you're tired.
By wingnit in forum Motorcycle Care
Last Post: 11-04-2020, 09:06 AM
By MrCleanit in forum Auto Detailing 101
Last Post: 10-21-2013, 08:36 PM
By richy in forum Flex Polishers
Last Post: 08-23-2012, 08:07 AM
By LSUFAN in forum Products Guides
Last Post: 01-27-2012, 12:28 AM
By heggiemd in forum Introduce Yourself
Last Post: 01-15-2008, 08:28 PM
