Results 1 to 7 of 7
    Oct 2010
    1,060
    Seat belt cleaning
    Anyone have a good method to clean the seat belt (actual seat belt strap)? I have scrubbed them in the past but they always soak up too much product and stain really easy
    Sep 2009
    1,308
    Re: Seat belt cleaning
    I spray it with either DP Total Interior Cleaner or DP Carpet Pre-Extractor treatment and then use a steamer. I wouldn't use anything that contains any kind of petroleum to clean because that'll weaken the webbing.
    Oct 2010
    1,060
    Ok thank you I will try it, do vacuum it dry instead of a towel? To suck the dirt out rather than pressing it in?
    Super Member Finemess's Avatar
    Apr 2009
    WNC
    2,316
    I use APC+ and a white towel, spray it on and wipe it off.
    'Cause there's just something women like about a pickup man.
    Rich
    Sep 2009
    1,308
    I vacuum first, then lightly spray some cleaner on it, then run a steamer over it. After all that I'll wipe it down with a dry towel.
    Super Member jlb85's Avatar
    Mar 2008
    Rochester, MI
    734
    There are specific "seat belt" cleaners out there you can use safely. Although most APC cleaners used here should be perfectly safe for such a resistant and well made material, harsh cleaners will deteriorate seat belts over time. Make sure to rinse the belts well after cleaning. Steam is good for stains and rinsing, but keep the heat moving over the belt.
    Local to Southeast Michigan
    Serving Nationwide
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    The Meguiars APC + works great with an upholstery brush.
  1. Cleaning Seat Tracks
    Last Post: 06-13-2018, 08:07 AM
  2. Seat cleaning
    By warmachine in forum Auto Detailing 101
    Last Post: 04-30-2017, 11:10 PM
  3. Best option for sun faded seat belt latches? These are bad
    By allenk4 in forum Tricks, Tips and Techniques
    Last Post: 01-04-2015, 09:38 PM
  4. Cleaning the seat belts?
    By nimo in forum Ask your detailing questions!
    Last Post: 10-28-2011, 11:32 AM
  5. Leather seat cleaning
    By Rspratt48 in forum Auto Detailing 101
    Last Post: 08-27-2011, 09:11 AM
