Results 1 to 5 of 5
    Nov 2006
    74
    removing years of oxidation and neglect?
    wife has a 89 Mazda MX6, no clear coat from the factory that i know of, and lots of oxidation (at least that is what i think the white spots are)
    will XMT #2 get it out? or 3M's Fine Cut Rubbing compound with a Orange LC pad on my 7424? i have access to all of the above
    thanks
    Super Member supercharged's Avatar
    Mar 2006
    7,305
    I never used rubbing compound by 3M, I think it is designed for rotary use.
    Remember, you want to start with the least agressive product, then if it won't do the job, move up to a little more agressive. So, start with XMT 2 on orange pad, do a little section at a time (18'x18'), then check your results. If it won't work, I would move up to XMT3 or SSR 2.5.
    Good luck.
    Nov 2006
    74
    but i should be able to give it some new shiny life?
    Super Member Kelso's Avatar
    Mar 2006
    spring hill, Fl
    1,075
    depends on how far the oxidation has gotten. but it couldnt hurt.... try xmt 2 or 3 if you hvae it
    Sep 2006
    2,397
    I would start as follows :
    XMT2 via orange, XMT3 via orange and then xmt3 via yellow if necessary.
  1. RUPES EASY GLOSS System - EXTREME MAKEOVER - 2006 Toyota Tundra - YEARS of neglect!
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 03-19-2019, 08:18 AM
  2. Replies: 10
    Last Post: 03-07-2012, 03:24 PM
  3. Three years of neglect need help!
    By Rei86 in forum Ask your detailing questions!
    Last Post: 04-15-2011, 04:19 PM
  4. Years of Neglect and Bad Oxidation....
    By Flyboy in forum Auto Detailing 101
    Last Post: 06-18-2007, 08:49 PM
  5. 2001 BMW 740iL Black - 6 years of neglect
    By Totoland Mach in forum Show N' Shine
    Last Post: 03-09-2007, 10:19 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
