Results 1 to 9 of 9
Thread: Hazy Windshield
    May 2010
    Hazy Windshield
    I can never seam to get the inside of my windshield haze free. I have been using Stoners glass cleaner with cotton towels and even microfiber towels. It will look clean until the sun hits it at the right angle and the haze appears. Any ideas ?
    Super Member Mindflux's Avatar
    Apr 2008
    668
    Re: Hazy Windshield
    Same problem with SIG here. Switch cleaners.
    Re: Hazy Windshield
    What are you working on?
    Brand new cars are prone to "Vinyl Fog", that's where you get a nasty film build-up of all the icky substances used to make the high plastic content of modern cars out-gassing inside the car and while the film is probably on all surfaces you see it on the window.
    One tip for getting windows clean is switch to a clean, dry microfiber after making the initial wipe to remove the film and glass cleaner. If you continue using the same cloth your removed the film and glass cleaner with then the chance that you will simply transfer this gunk back onto the window is always a possibility.
    In the Diamondite line there's Diamondite® Glasswork Restorer, which can be used by hand to cut through and dissolve any stubborn films and then afterwards clean with a glass cleaner.
    Super Member S2K's Avatar
    Jul 2010
    990
    Re: Hazy Windshield
    I used SIG for the first time today and I did notice after cleaning a slight haze to the glass so I buffed with a clean dry MF and the haze went away and was very clear. I had read good and bad results with it and decided to try hoping I would be one of the good and I think I was.
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Re: Hazy Windshield
    I find the aerosol version of Invisible Glass to remove the haze on glass best. You do need to spray liberally before removing. Stay outside of direct heat and sunlight. Consider rebuffing with a clean towel or flip to a clean/dry section.
    Scott
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Re: Hazy Windshield
    If its possible leave your windows cracked a 1/2 inch or your moonroof in the tilt position. This will help reduce this fog you speak of
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Re: Hazy Windshield
    There's all sorts of things inside a car that sticks to things like glass. Vinyl out-gassing, smoking, and even AC seem to leave a film on it as well.
    The key to an easy clean relies on routine maintenance and using a quality cleaner and Microfiber glass towels. I say glass towel because the waffle texture of this towel clean and absorb better than a Microfiber polishing towel. Cobra makes a nice one and the one's I use regularly. I found that cotton towels tend to smear and spread the messy film rather than remove it.
    I clean my glass with Stoners Invisible Glass and a Microfiber glass towel. This combination cleans very well and leaves a streak-free shine. An area of frustration is always the corners and those hard to reach areas. I picked up one of these gizmo's, it works pretty nice and avoids all the twisting and contorted positions normally associated with cleaning.
    Junior Member Millennium's Avatar
    Jan 2010
    Atlanta, GA
    38
    Re: Hazy Windshield
    I use invisible aerosol glass cleaner and 2-3 microfiber towels. Never use too much glass cleaner. I do half of the windshield at a time. Concentrate on buffing away the haze rather than applying more solution.
    Millennium Auto Care
    http://detailing-solutions.myshopify.com
    Follow me on instagram @millenniumguy
    Super Member Impressions's Avatar
    Oct 2009
    palm city florida
    586
    Re: Hazy Windshield
    first step is cleaning the top edge....open window slightly, clean inside and outside edge, close window, As for window cleaner I've found that less is better.....by less I mean just enuf window cleaner to clean the glass, not saturate it. Picture frame the window (wipe around the outside) first, than hit the center, turn microfiber and repeat. I have very few problems with glass
    Sometimes if they are real badly smoked in, I'll saturate the glass, wipe, let dry than repeat with my first method
    Most of the glass cleaner I use I won't cut---use it straight
    on cars that I wash weekly, most of the time I just use a clean damp microfiber towel and use the same method without window cleaner
    Robert DiTerlizzi, 772-260-6636
    Impressions Fine Automotive Detailing
    7656 SW Jack James Dr.Stuart, Fl.
  1. Hazy
    By Jmickle in forum Auto Detailing 101
    Last Post: 01-07-2014, 05:57 AM
  2. hazy hood
    By garfy in forum Ask your detailing questions!
    Last Post: 10-28-2013, 06:16 AM
  3. Windshield getting hazy
    Last Post: 09-05-2013, 11:56 AM
  4. Hazy 99 Harley
    By SeaJay's in forum Wet-Sanding, Cutting & Buffing
    Last Post: 05-04-2011, 11:40 AM
  5. finishing out hazy
    By redtail in forum Auto Detailing 101
    Last Post: 10-25-2008, 05:08 PM
» February 2024
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 12
