pls. clarify detailing process
I know the rule of thumb is to start off with the least aggressive polsih before using a more aggressive one. let's use the XMT line as an example for this.
if I don't get the results I want with XMT#1, use XMT#2 (or 3), right?
So, if I use XMT#2 over #1, do I have to make a pass with #1 all over again before glaze and wax?
If you don't get the results with XMT#1 step up to XMT#2. Try different pad combinations on XMT#2 and if that works, and you leave no micromarring or hazing then you can go to glaze and wax. BUT, if XMT#2 removed the big swirls and left it's own micromarring or some hazing, you should use XMT#1 to "jewel" the surface and leave a perfect canvas for your glaze and wax. Remember, the key to an awesome looking car ISN'T the wax, it is the preparation. Good luck.
thanks, abrcrmbe...
i guess another rule of thumb (for me) would be "don't be lazy and do the whole process!!!""
lol
You also have to look at the surface and see it's condition. If there are a ton of swirls, there's no need to start with #1 and most of the time, #2. And vice versa. I can get #3 LSP ready on most paints. It's alot about technique and experience.
Here is my "rule of thumb"
- Start with One Section and use the least aggressive polish/pad combo to get the job done. This will depend on the severity of the imperfections, but the majority of time start with a medium aggressive polish and polishing pad.
- Work polish in completely (see polish breakdown stages), remove residue, check work, repeat (if needed) or go more aggressive (if needed) either by using higher speed, more pressure, a cutting pad or more aggressive polish.
- After scratches/swirls are removed or minimized, step down to a less aggressive polish/pad combo to remove any hazing left from the more aggressive polishes...again, repeat if necessary.
- Once the desired finish is achieved then move on to the other sections of the car.
- By starting with one section it will allows you to see what product/pad combo is needed without going too aggressive or not aggressive enough to get the job done.
You also NEED to watch this if you have not already......
http://www.autogeek.net/po.html
That is a very sapient post.
I think that I am your biggest fan, BlkYukon.
Very informative post!!!!
cwcad
Do What You Say....Say What You Do!
www.ldkbox.com a blog about life's details
I appreciat blkyukon's time and effort in his vids. They were the first ones I had ever seen. Taught me so much about the PC.
Thanks bro.
Justin
thanks, blkyukon, very informative. hopefully i can get these steps together after I decide on what products to get...(that's another headache, lol)
Last Post: 01-17-2020, 04:43 AM
By JWilliams.RadiantDetail in forum Product Reviews
Last Post: 01-03-2020, 10:04 AM
By taej in forum Auto Detailing 101
Last Post: 03-07-2014, 08:34 AM
By kismit79 in forum Auto Detailing 101
Last Post: 06-25-2012, 09:54 PM
By paradog in forum Auto Detailing 101
Last Post: 01-19-2008, 05:45 PM
