Re: Need Help Removing Swirls Out of Black Paint!
Quote:
Originally Posted by
jzuniga01
So can I use the Ultimate Coumpund, Swirl x, pre wax cleaner, Black Hole and then top it of with P21s?
Sure you can... you don't need to but if you want to use up some products for the sake of using them up I say go for it!
You only need to,
Wash
Clay
Clean
Polish
Seal
KISS = Keep it Simple Simon
Wash
Clay
Ultimate Compound
SwirlX
Seal
I think the Man vs Machine lays this out pretty well?
:props:
jzuniga01
Or can I just use the Swirl X and then the other products without using the Compound? I am just scared of messing the paint more than what it is with the compound.
Yes.
"Use the least aggressive product to get the job done"
If you find the Swirls isn't aggressive enough you can always get more aggressive.
Remember and read what I wrote about dong a TEST SPOT
Find out what you can do with ANY product by hand or ANY machine to a small area before going over the entire car. You can find out what you can do and if you like the results form the small test spot you'll probably like the results over the entire car.
The Test Spot helps you to find out what you can do with what you have before wasting your time.
How's that?
ok I am done thanks for everything!
Let us know how it works out for you. Others may want to repeat your process and your experience.
