Avoid scratching when using a QD?
I was thinking about it, and it seems to me there's NO way you can avoid marring/scratching the paint while QD'ing. There's just not enough lubrication when using QD's and a whole lot of friction, even with a light layer of dust. The only way to avoid scratching the paint would be to wash the car, or using a QD right after washing the car. Anyone else agree?
Re: Avoid scratching when using a QD?
Not exactly. A good QD will have adequate cleaning power to loosen dirt, and a good amount of lubricity to avoid scratching. The two keys, in my opinion, are 1. don't push it too far / know the limits of the QD. By this, I mean don't QD a car that has a clear layer of DIRT on it. Use it for light dust or spot removal (bugs, etc). 2. EASY on the pressure! Applying pressure, especially on soft paint will almost always cause marring. Let the QD do the work!
Just my .02...I've had great luck following these two simple "rules" of QDing.
Well, I guess when your putting a towel on your paint, even a MF towel, there's always a possibility of introducing scratches. However, if you use enough QD and are careful enough with the towel you really should be okay, especially if you're just using it to get dust off.
I just bought DP Waterless to use on anything more than mild contamination. This gives me peace of mind before applying QD. BTW I like FK425 and OID best of all QD's I have tried. I agree that the process is most important part of application.
It's also inportant to use a really good MF and like others say don't use alot of pressure.I also work slow on my Qd turning the Mf offen folded into fourth's.
I agree with Harley Guy - I often use 2 MF 16 X 16 high quality towels folded in quarters on an average car that I know has a great coat of wax on it. Those two towels folded that way give me a total of 16 surfaces to use on the one vehicle. I will always start at the top of the vehicle and finish with the ares just to the rear of all 4 tires where often the worst form of contamination is.
Use high quality MF. Also, we only use plush type MF for QD and final wipes (including sealant removal). Further, QD is just that, a quickie. If the surface has more than "almost nothing", I'd rinse it down first.
But if Matt can keep his S2000 swirl free while QD'ing, anyone can! S2000's have some super soft clear, and require even more insane MF care than other cars (I'm still thinking about the White Ford Cobra that took 5 passes of Power Gloss and M105)...
Local to Southeast Michigan
Serving Nationwide
Look into some 80/20 blend MF towels. Like matt stated, you want enough lub to keep from re-marring the surface and with a soft towel, chances of that happening are lowered. However, i have no clue how someone with an S2000 can keep it marring-free using QD hahah...you must be God's Detailing Child
Hi Mark,
This topic has been coming up ever since detailing forums have been around because after people get the paint on their project cars all polished up their next concern is how to keep it that way?
Lots of great comments so far and all I want to do is point out that sooner or later you have to 'touch' the paint somehow? Either by normal car washing, touch-less car washing, using a spray detailer, using a rinse-less wash, etc.
Whichever approach you choose to use, just do your best to use the best quality products you can obtain and the best technique you can muster.
When using a quick detailer, if you want to do the most you can do, then be sure to use plenty of microfibers, versus just a few, you could get extreme and after making a single wipe with one side of a folded microfiber, fold to a clean size and only use the the face of a folded microfiber a single time. This would insure you never rub particulates removed off one section over a new section.
Kind of like what I've been telling people about fixing rock chips with touch-up paint for years and that's you can make it as complicated as you like!
The other option isn't very practical and that's to park the car in the garage after it's all polished up, cover it gently and don't drive it.
I think I will only use a QD as a drying aid after washing my car, this way I'll have some additional gloss and slickness instead of drying without it. Won't touch the car again until it's washed. As was stated, the less you touch the paint, the better. Makes sense!
By Andre1961 in forum Ask your detailing questions!
Last Post: 10-14-2019, 10:42 AM
Last Post: 12-12-2017, 09:06 PM
By alexramsey in forum Ask your detailing questions!
Last Post: 12-12-2017, 04:51 PM
By squelchy451 in forum Auto Detailing 101
Last Post: 11-22-2017, 03:10 PM
By cannondalemr in forum Auto Detailing 101
Last Post: 05-01-2008, 08:14 PM
