» Detailing Classes
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Member
    Aug 2009
    96
    Tough Decision..... a little help please
    Im going to be ordering a DA buffer. Im not sure what kit yet and I hear everyone rec the Groits is their a big differance between that and the PC? thanks in advance
    Senior Member PAR Detailing's Avatar
    Oct 2009
    Louisville, KY
    894
    Re: Tough Decision..... a little help please
    I have a Megs and my roomate has a PC. I have used both and I personally like the Megs... because its mine haha just kidding... but I feel there is less vibration in the handles and machine. Other than that they work equally as well. I dont know if that helps
    Peace
    Jon
    Senior Member HighEndDetail's Avatar
    Apr 2006
    Cobb county, GA
    1,881
    Go with the griots. I hear it works real nice and has more power. I have the old PC and plan on getting a griots, to go with my flex 3401
    Ed
    Moderator/Consultant for Autogeek.net
    To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
    While my approach takes more time, the results are far superior.
    Senior Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    Griots or Flex ..
    Scott
    Member
    Aug 2009
    96
    thanks everyone groits it is!!!!!
    Senior Member sullysdetailing's Avatar
    Mar 2009
    South Florida
    1,963
    Quote Originally Posted by tims04gto View Post
    The Griot Garage is alot more power full the the PC. The Griot Garage is more like the Flex DA but smaller more compact and easier to use. It is powerfull enougth to power a 6'' pad with is pretty impressive for a DA. Since you are knew to a DA I would recommand the Pinnacle Advance Swirl Remover, Pinnacle Advance Polish, and Pinnacle Liquid Souveran (I believe that is on of the kits) or Wolfgnag 3.0 TSR, Wolfgang 3.0 Finishing glaze, and Wolfgang 3.0 Paint Sealant. These are great kit to start off and learn with. Both kits work very well and are very easy to use.
    Shawn
    Sully's Detailling LLC - South Florida
    www.autogeek.net
    Senior Member loudog2's Avatar
    Aug 2008
    St. Charles, IL.
    2,880
    I wouldn't compare it to the flex. The flex has forced rotation and more orbital rotations. The orbital path on the griots is 9mm vs. 8mm on the flex. The flex has 3ft more cord alsoa nd a 10 amp motor compared to griots 7 amp motor.
    GRIOTS Features:
    More Powerful 7-Amp, 850-Watt Motor
    2,500 - 6,800 Orbits Per Minute
    Variable Speed, Wider RPM Range
    Wider 5/16" orbit pattern for faster and better results
    Ergonomic Adjustable Handle
    More Torque, Better Performance
    Longer 10 Foot Power Cord
    Backing plate included
    FLEX features:
    Maximum polishing pad diameter 160 mm or 6.3 inches
    10 amp motor
    Velcro pad 150 mm or 5.9 inches
    Speed without load 160-480 rpm
    Orbit (stroke length) 8 mm or 0.31 inches
    Orbit rate, without load 3200-9600 rpm
    Power input 900 Watt
    Power output 590 Watt
    Weight 2.60 kg or 5.73
    13ft power cord
    Member
    Aug 2009
    96
    the flex is out of my budget right now im looking at the groits or pc
    Member
    Aug 2009
    96
    i like that i can use many pad and brush configurations too
  10. #10
    Aug 2008
    St. Charles, IL.
    2,880
    I know, just didn't want you thinking the flex and griots da's were about the same.
  1. Decision Decision
    By Lumorales1975 in forum Rotary Buffers
    Last Post: 03-27-2018, 08:29 PM
  2. Help me make the RIGHT decision!?!?!
    By Guest51 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 10-22-2014, 01:30 PM
  3. my decision
    By stilltipping3 in forum Auto Detailing 101
    Last Post: 10-20-2013, 06:45 AM
  4. Help with decision
    By jminrod in forum Auto Detailing 101
    Last Post: 09-02-2012, 09:20 AM
  5. I just made a big decision!!!
    By mcpp66 in forum Auto Detailing 101
    Last Post: 08-23-2010, 01:06 PM
Members who have read this thread: 77
» April 2020
293031 1 2 3 4
26 27 28 29 30 12
