Thanks everyone. One more thing though, can I apply Klasse SG immediately after AIO or should I wait a few hours?
No cure time on the AIO. You can apply SG right away. There are a bunch of tricks for using SG. Killr had the best system IMO. Couldn't find it but it may still be on here somewhere. One I used was after applying SG I didn't wipe it off for 12 hours. Then I'd let it cure for another 12 hours. So I'm with supercharged on the finiky/24 hr.
Thanks Jimmie.
Killr, do you have a system when it comes to Klasse SG?
Can anyone else chime in on leaving Klasse SG on for 12 hours before wiping it off and then letting it cure for another 12 hours?
BTW, I will be applying Klasse SG on a LC CCS Blue with a FLEX. Thanks.
I have found the only way to use the finicky Klasse SG, is to transfer some to a small travel size spray bottle and mist a panel and immediately buff in, flip towel and buff off. If you get a stubborn spot then respritz and immediately buff till gone. Works like a charm and offers the same long term durability but allow the curing time between layers or topping with 'nuba.
