foamaster help
Just took foamaster gun (quart) out of box.
DP wash.
How much soap?
Do I than fill with water, or let washer do dilution?
Can you get clear water by turing pin upside down or pushing to tab end, or
does it require a hose disconnect?
What's the tiny adjustment screw on top?
Any other advice from experienced users?
Thanks
Re: foamaster help
Good questions. I'm just here hoping to get the answers too.
Re: foamaster help
hint : fill canister with water first, then add about two ounces of soap for the smaller canister (quart size). Use the adjustment rod on top for more foam. (little holes in pegs lock in)
Re: foamaster help
Thanks so much.
can you get clear water through, or do yyou have to disconnect?
does the little screw(valve?) on top serve any purpose?
Re: foamaster help
the screw on top needs to be tight, dont lose it. It allows to much air in and foam goes bye-bye.
I have a Dramm300 cutoff on mine, and just quick disconnect and fill, then pop back on in a cool second. Quick connects rule !
By Dewy in forum Ask your detailing questions!
Last Post: 08-24-2013, 08:26 PM
Last Post: 08-23-2013, 08:27 PM
By nissenc1337 in forum Auto Detailing 101
Last Post: 03-07-2013, 01:20 PM
By andrew b in forum Ask your detailing questions!
Last Post: 12-14-2011, 04:20 PM
By Locutus in forum Auto Detailing Tools and Accessories
Last Post: 06-24-2010, 11:20 PM
