Results 11 to 20 of 22
    Dec 2018
    7,326
    Re: Ceramic maintenance spray
    Everyrhing mentioned has been great. For drying aids I like Megs ceramic detailer, Ech20 and Griots ceramic detailer.
    For toppers my go to are pretty much anything Polish Angel and Kamikaze OverCoat always got on hand. A inexpensive but also good product is Dr. Beasley’s Bead hero.
    I’m sure some one will be here soon touting ADS as they seem to be new flavor of the month and well deserved based on reviews from well trusted members.
  2. Likes chilly, BudgetPlan1 liked this post
  3. #12
    Super Member Danube's Avatar
    Jan 2012
    Australia
    1,193
    Sonax BSD is doing great in my opinion.
    Flex 3401 & PE14
  4. Likes chilly, msharpe785 liked this post
  5. #13
    Regular Member Vegas1's Avatar
    Mar 2006
    Central CT
    145
    Technicians Choice TEC 582, CarPro ECH2O and Meguair's Hybrid Ceramic Detailer.
  6. #14
    Aug 2013
    St Louis metro (Illinois)
    5,896
    What's everyone's thoughts on NV Nova Boost? I've been thinking about their products like Luster and Jet for a while and never pulled the trigger since I already use more durable coating. I'm not sure when Boost came to market, but it looks like it would fall into this category.
  7. Likes chilly liked this post
  8. #15
    Super Member chilly's Avatar
    May 2006
    Alaska
    2,167
    Of the 7 products I tried on the TX a couple weeks ago, Boost was one of the nicest to apply and seemed quite slick and silky
    I did make the mistake of buying the older Boost instead of the newer V2, but I have no basis for comparison so who knows how much different/better the new version is
    It is supposed to assist the coating to do its thing, not actually add something like a topper would
    I haven't come to any long term conclusions yet
  9. Thanks Desertnate thanked for this post
  10. #16
    Super Member joebruin77's Avatar
    Jan 2019
    268
    I am one of those that recently tried Armour Detail Supply Amplify and was very impressed. I highly recommend it. I also like TEC 582 and Xtreme Solutions Topper.
    I have wanted to try NV boost. My only gripe about it is the price. Once I find a product I like, I like to buy it by the gallon, to make it more cost effective. Both TEC 582 and Topper are a great value when you buy them by the gallon ($40-$45). Amplify is just a bit more expensive at $49.99 per gallon and you can easily find discount codes for 10-20% off.
    NV Boost appears to only come in 500ml or 1 liter. The 1 liter is offered at $28 per liter, which works out to $105.84 per gallon. I haven't personally tried NV boost, but is it really worth 2-3 times the price as these other quality products?
  11. Likes chilly, Karl_in_Chicago liked this post
  12. #17
    May 2006
    Alaska
    2,167
    Quote Originally Posted by joebruin77 View Post
    I haven't used TEC 582 in quite a while but remember it very fondly, in fact when I use 3D Bead it Up I almost think I am using the TEC
    I buy very few chemicals in gallons these days other than soaps, prewashes, microfiber detergent, etc and therefore I honestly don't pay much attention to the cost per qt/lt/gal and just buy and use what works and is enjoyable
    I bought a half liter of the Boost to try and that will last me quite a while, and by the time I need more there should be enough feedback on the Version 2 that if I want more I will probably buy a liter and be set for a long time
  13. Likes joebruin77 liked this post
  14. #18
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,458
    There are two versions of Boost, the original and the v2 version that arrived about two years ago.
    Boost - this is a spray and wipe quick detailer designed for maintaining ceramic coatings. The concept here is you use Boost as a drying aid or topper after each wash, in the process laying down a short-term sacrificial layer, while also providing some additional gloss and slickness. That's pretty universal stuff, but what separates Boost is that it is removed at the next wash using soap, in turn taking contamination with it. You then reapply and repeat the process. Because of that concept, I use Boost as a topper for my wheel coating to help with brake dust.
    In use, I wouldn't say Boost is the slickest and glossiest quick detailer or ceramic topper, but its pretty simple to use, and that short term layer concept is somewhat unique.
    Boost v2 - where the original provided short term results, Boost v2 produces lasting protection, gloss and slickness. This is a much more conventional ceramic spray sealant/detailer in that can be used as a topper or as a standalone protectant, which "can last anywhere between 3-6 months depending on driving/storage/paintwork conditions". I think Boost v2 has been more widely accepted because of its longer lasting effect.
    I have found v2 to produce a slicker, glossier surface when compared to the original, it will also produce some decent hydrophobic properties. Boost v2 can get a bit streaky if over applied.
    While I do use both and, I wouldn't say they sit above and beyond other similar products, especially if the short-term concept of v1 is of no interest to you. We get NV products relatively cheap in Australia, but I wouldn't say the price premium they command in the US and Canada is worth it.
  15. Thanks chilly thanked for this post
    Likes joebruin77, chilly liked this post
  16. #19
    Aug 2013
    5,896
    You guys buying product are pretty brave unless you're using it for a business. Gallons of a detail spray would last me a lifetime. I'm almost afraid to think how long my bottle of ECH2O has lasted me so far. I've only purchased one...years ago. I just don't go through the stuff that fast.
    Quote Originally Posted by DFB View Post
    There are two versions of Boost, the original and the v2 version that arrived about two years ago....
    Wow! Thanks for all the info. I know I found it useful and hopefully others will too.
    While it sounds pretty good, I might stick to Amplify since the application is almost fool-proof.
  17. Likes DFB liked this post
  18. #20
    Mar 2022
    Quote Originally Posted by SNP209 View Post
    First and foremost you need to wash it frequently with a quality shampoo. Meguair's Hyper Wash is affordable and can be bought locally at harbor freight if need be. To maintain hydrophobic properties I'll put in another vote for Meguair's Hybrid Ceramic Detailer which can also be bought locally.
    Here is a good video by fellow forum member Loach showing Hybrid Ceramic Detailer in action:
    Two big thumbs up for Loach and his channel. The toppers/detailers he reccomends are excellent
  1. Replies: 0
    Last Post: 06-17-2021, 08:02 AM
  2. Replies: 17
    Last Post: 01-05-2021, 07:04 PM
  3. Ceramic coat - maintenance
    By jvamagic in forum Auto Detailing 101
    Last Post: 10-19-2019, 01:39 PM
  4. Noob! Help with ceramic wash/maintenance.
    By vilastrex in forum Auto Detailing 101
    Last Post: 08-30-2019, 12:58 AM
  5. Replies: 8
    Last Post: 03-24-2018, 11:39 PM
Members who have read this thread: 76
» July 2024
30 1 2 3 4 5 6
28 29 30 31 123
