Griots wax left water swirls on paint
I recently purchased Griots 3-1 Ceramic Spray Wax. I am now left with water swirl marks all over the paint. It is silver so it sticks out really strong. I tried washing twice and they are still there !
how do I get rid of them? I will try to get a picture today, but it looks like dried water marks. As if I didn’t dry the vehicle off after a wash.
Re: Griots wax left water swirls on paint
Try spraying a microfiber towel with more of the 3-1. Then wipe the swirls away. The solvents used in the spray will pull up the high spots of the wax. More than likely you used way too much to begin with. You only need 1 to 2 sprays per panel (maybe 3 sprays for a large panel like your hood). A little goes a long way with this product.
I also always recommend the two towel method. You first spray the panel then use one microfiber towel to spread the product quickly and evenly. Then the second towel comes in and buffs the panel so it’s streak free.
I’ll make one other point, that your microfiber towels should never be washed with regular detergent and should never be dried with dryer sheets/fabric softener. The dyes, additives, and softeners will spread all over your car’s paint and leave streaks all over.
I appreciate that. I am sure I used too much as it was my first time using it. I have always used two towels and never use detergents. I use something I got online here for cleaning, some foam pad / microfiber cleaner. I’ve used it for a long time so I’m not saying it’s not me. But it shouldn’t be anything with the towels.
I did a quick wash with my regular Pink soap, dried as normal and reapplied the 3-1 (2 towel method) and it’s still showing. Should I clay bar it? Light polish? It’s not everywhere but when you see it, you see it !
You didn’t try to use it as a “detail spray” did you? If so, that would explain why you instilled the swirls.
What do you mean by that?
Originally Posted by
01AUDI
Alot of people nowadays tend to describe spray sealants/spray waxes as “detailers” aka quick detailing sprays and therefore use them as quick detailing sprays i.e. use them to wipe dust off their paint, which in turn is a mistake that will lead to instilling swirls.
01AUDI
Clay probably won’t do it it well. I’d do a light polish.
I’m guessing that’s a yes?
Eldorado2k
I think they’re running into high spots from the ceramic portion of the 3-1 vs swirls instilled into the paint from dirt/dust/debris.
As others have mentioned, if a reapplication doesn’t reactivate the wax enough to buff off the high spots, you’re probably stuck doing a light polish to get back to square one.
No, I did not use this as a detailer. My experience is after a complete two bucket wash, and complete towel dry.
