Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Apr 2020
    60
    gyeon can coat evo maintenance
    hey guys coated my car with can coat evo pretty wild product! as far as topper/maintenace goes for it besides using resest as a soap, is reload or hydro 2 gonna serve the same purpose/ durability? wouldnt i be better of with hydro2 (spray and seal)? or is reload (buff and shine) a superior product. arent they both sio2 infused?
    Dec 2018
    7,167
    Re: gyeon can coat evo maintenance
    Reload will be a more stout product. You’ll contact paint less with spray and seal.
    I like applying stuff to paint so I would go reload.
    Debate with maintenance products if needed at all.
    Coatings are known to water spot and I had no issues with my coating (CQUK3) with waterspots topping it with Polish Angel Cosmic Spritz.
  3. Likes CleanIT, Craig Encinitas liked this post
  4. #3
    Sep 2015
    2,173
    My truck is coated with MOHS EVO. I use the Gyeon Ceramic Detailer as a maintenance product. Surface is so slick a fly couldn't land on it. Will probably put Cure on it once every six weeks.
  5. Likes opie, The Guz, dgage, CleanIT, Craig Encinitas liked this post
  6. #4
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,226
    Damn it i forgpt about wanting to try cosmic spritz this year...how long does it usually last as a topper? Im not one to reapply something every wash. More like id be ok with doing it every month or month and ahalf
  7. #5
    Dec 2018
    7,167
    Quote Originally Posted by opie View Post
    Cosmic will give you coating like performance applied monthly. Every month or two is fine. REALLY nice and easy to apply as a drying aid.
  8. Thanks opie thanked for this post
  9. #6
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by briarpatch View Post
    You won't even need cure if you are using the ceramic detailer.
  10. Likes Craig Encinitas liked this post
  11. #7
    Nov 2021
    52
    I use Gyeon ceramic detailer on my can coated daily driver. I like using products from the same family. Ceramic detailer is all you need. I use once a month after maintenance wash.
  12. #8
    Mar 2021
    Pa
    2,226
    Quote Originally Posted by Forty View Post
    Does it smell like cure?Cure smells so good
  13. #9
    Sep 2015
    2,173
    Thanks for the advice.....I was not sure if (periodically) I should use something a little stronger than the Ceramic Detailer
  14. #10
    Dec 2018
    7,167
    You can if you want but not needed. Me I just like to try different things so I say go for it.
  1. Gyeon Can Coat
    By Dynoguy in forum Ask your detailing questions!
    Last Post: 02-01-2023, 10:11 AM
  2. GYEON Coating Maintenance: Bathe+ vs WetCoat vs Cure
    By Jeff at Gyeon in forum GYEON Car Care Products
    Last Post: 05-22-2020, 09:11 AM
  3. Ceramic coat - maintenance
    By jvamagic in forum Auto Detailing 101
    Last Post: 10-19-2019, 01:39 PM
  4. Review: GYEON Q2M Leather Cleaner and GYEON Q2 Leather Coat by Mike Phillips
    Last Post: 02-19-2019, 08:13 AM
  5. Opti-Coat Maintenance
    By Boejoula in forum Auto Detailing 101
    Last Post: 06-23-2016, 03:52 PM
