Re: Bought a Tornador Max.
Originally Posted by
DanaDetailingPros
Just get a Hepa filter for now. I use a Cleanstream Hepa filter in my 14 gallon Ridgid.
DanaDetailingPros
That's what I have. Amazing unit. All you hear is the vacuum of the air. The motor is so quiet. So strong it has a knob to dial-down the power too. It's a little over-kill but hey, Chris is a buddy and fellow Buckeye and I like supporting him.
TTQ B4U
Do you leave the HEPA cartridge in place for wet pickup (ie. Tornador use)? How often do you clean that element?
SameGuy
I only use the Flex Dust Extractor on dry materials. It can be used for wet, but it's rare that I will use the Velocity Vac on wet anymore as I also have a true dedicated hot water extractor. If/when I used the Velocity Vac with moisture, I use my smaller portable Ridgid 3 gallon. The Hepa in the flex is said to go 3-5 years. It has a 3-stage filtration system for intake and one for the exhaust too. First the bag, then a panel filter (similar to a car intake), and then the HEPA canister sealed inside.
Is that a rebranded Sandia? [Note: I may have subconsciously absorbed that if you’ve posted about it previously, but I’ve been googling vacs and extractors a bit too much recently as well]
SameGuy
Yes. Sandia 6 Gallon. They private label their products. Our local distributor is a repair center too so they rebuild, customize and carry all the parts, etc. Beautifully simplistic design under the hood and super rugged.
When I googled the Flex 44, I got maybe a dozen different, identical-looking vacs from Makita, Milwaukee, Nylfisk and more. Who actually designed it as a white book?
Eldorado2k
TTQ B4U
TTQ B4U
SameGuy
SameGuy
CRAZY PRICE!!! Wish I had a shop
Reason: Links
TTQ B4U
Has the best specs on any extractor under 2K! 205" lift is insane!
I need to order a few parts to use the Tornador max with the Vac attachment. I was considering buying a gall of there enzyme cleaner since I had to pay freight anyway. Do you recommend a better product to use in a gallon size that's a decent price?
