Re: Can I polish decal stripes?
Originally Posted by
Flash Gordon
If you use a claybar be super careful around the edge of the stripes.
Yes.
Only run the clay "away from" the edges.
Not "into" the edges.
Bdubbs
I believe mine are a gloss finish. Is there a way to know for sure?
I can use a 3" pad along with my Porter Cable?
Thank you.
Sent from my moto g power (2021) using Tapatalk
They are gloss vinyl from your photo. You can use a polishing pad to start out with and the same polish you will use in the paint. Do a small test spot first.
I appreciate all the help!
Are you guys recommending trying the 3D speed over my Wolfgang total swirl remover followed by finishing glaze, then there paint sealant?
Bdubbs
I've never used the Wolfgang brand so can't give an honest comparison. If that's something you already have then I would probably use it.
If you want to save some time you could use a ceramic spray on that last step.
