Re: First day using Bilt Hamber touchless.
Originally Posted by opie
Blonde moment...what do you mean?
Sorry If you wet the car 1st. Don’t, touchless should be applied first while car is dry.
You don’t want to pressure wash caked on gunk and grime. You want Touchless to go in car dry… soften road grime/film and then pressure wash off.
Originally Posted by CleanIT
I think what I’m going to do going forward after I polish and apply new coating next year, is use BH Touchless (or any effective prewash) as much as possible and follow up with a spray and some sealant. That will reduce how much I am touching the paint and will cutdown on swirl marks.
So touch-less is suppose to be a part of a system. The have a second step that can be sprayed on or used in bucket wash called Touch On. It’s suppose to have detergents to aid in more cleaning or ok to be used by itself in a bucket.
I wouldn’t personally use anything after just touch-less as I don’t feel surface is clean enough. Also I would probably use a soap with protection vs a spray and rinse as if Bilt Hamber added a detergent to Touch On they probably feel the paint needs a little more cleaning after Touch Less.
Copy that tha ks, i do dry too, so i was making sure i was right...you've been using bh way longer than me
How did you like Frothe? Messy at first?
Yes. I only used it once because of that, very messy. Feels pretty slick but I still think a rinseless, if possible, is superior.
It also forced me to take my foamer apart and clean the filter inside, once Frothe dried in there it seemed clogged.
Right, I foamed the car while dry because that will help the foam cling more and won't further dilute the product.
Originally Posted by chilly
And on a separate note I am kicking myself for not thinking about ordering the special pump to dispense the BH 5 liter jug products
PITA
I did order that with it and it's pretty nice. I have to measure it and make sure it's dispensing 1oz per pump, this time I just trusted it but I'll verify next time, just to be sure.
It also drips after you pump (even though it claims to not drip). I used a small rubber cap to plug the pump and avoid finding a mess later.
Crazy how differnt experiences are. Frothe is only thing that doesn’t clog my IK’s . If not a Frothe fan…. Use it as a pretreat for rinseless.
I had to get use to the Fan of the sprayer but now I don’t spray it everywhere. It “dissipating in the cracks I couldn’t get it out of unsettling at 1st.
Now I’m quicker than a Rinsless (unless I use a Rinseless sponge, that is the quickest).
The key is to just remove bull of the foam with first pass and then rest with drying towel. I was trying to get everything with first towel and was driving me bonkers…. I use several drying towels now.
Yeah I got my AutoFoam a very long time ago from UK and it has a standard cap. The big mouth on the Touchless is annoying.
So....Amazon finally got it right and delivered Touchless to my door last night. Tried it at 4% out of an IK Foam Pro 12 on my wifes Yukon. Vehicle had some decent road grime, thanks to some really cold temps and driving on rain soaked highways. It did a very good job with the heavy lifting, much better than Car Pro Lift. All in all, an excellent product and a good value.
Side note - I will trying it out of a foam cannon next, and will be putting it up against BH Surfex HD (10:1) to see which one actually works better as a pre-wash.
I'm going to try Surfex as a pre-wash at some point but it seems to me that Auto-foam and Touchless are engineered to work on your paint, the others really aren't if that makes any sense
I recently tried DIY Detail All Clean which has a pH of 12 and I used 4 oz in my IK Foam Pro 12 last night on my g/f's car and it left dirt/salt on the bottom portions. They told me to try 5 oz instead of 4 oz, we'll see
2022 Elantra N Cyber Gray
By swanicyouth in forum Auto Detailing 101
Last Post: 07-05-2019, 06:47 AM
By HU11LK in forum Auto Detailing 101
Last Post: 09-20-2017, 09:33 AM
By boogyman in forum Auto Detailing 101
Last Post: 09-04-2017, 03:58 PM
Last Post: 08-15-2017, 04:49 PM
Members who have read this thread: 78
- SRider,
- vaca22,
- pdl2mtl90,
- Sonic Pilot,
- raysaint,
- Jackismydog,
- Mike Moore,
- Rmd,
- mc2hill,
- waddell64,
- TroyScherer,
- barryscott,
- Vegas1,
- AudiOn19s,
- fastfreddy,
- grovlet,
- zero4,
- MarioSH,
- D.BRITT,
- 02whitetundra,
- Rsurfer,
- dbeng,
- Odrapnew,
- Ivana Biharyova,
- talonted,
- mww,
- lewlsauce11,
- Bosko,
- PouncingPanzer,
- Prange,
- Dynoguy,
- kttlbll,
- kantonburg,
- oneheadlite,
- Azure,
- Urmil,
- uriel250,
- RPPM,
- Dirty Harry,
- Thunderchicken,
- Willbeen,
- vobro,
- hoyt66,
- Dan K,
- Bert31,
- briarpatch,
- boosteddub69,
- craigdt,
- Mustard,
- chefwong,
- Ace22,
- Loach,
- brianshaeffer,
- Bruno Soares,
- bapatickmjnra7168,
- ellens2,
- MisterSnoop,
- Texchappy,
- Wknd Dtlr,
- Desertnate,
- msharpe785,
- SNP209,
- FocusSTguy,
- Silly Rabbit,
- MCA,
- DanaDetailingPros,
- DFB,
- bill walsh,
- Optimus Grime,
- BTW574,
- tvu,
- YMMV,
- Sfs4567,
- CleanIT,
- filhotran,
- Nav45,
- Setec Astronomy,
- cb804
