Re: Lake Country HDO/CCS
Originally Posted by
JustJesus
Oh wow. 12. That's almost down the middle, slightly leaning closer to 15 than 8.
Leave it to me to complicate things...
lol
If I went with the 12mm machine I could buy HDO pads just to be safe but they are double the cost of the SDO
Just thinking out loud at this point
I know this is a Lake Country thread but the B&S Uro-Tec pads are well liked too though I usually use those with the Flex CBeast so not exactly the same but I’m sure there are a lot of users with regular DAs using those pads. Just throwing that out there in case prices are a little better than HDO.
Post Thanks / Like - 0 Thanks, 5 Likes, 0 Dislikes
dgage
Depending on where I look they kind of split the difference between HDO and SDO, pricewise
I have seen and read good things about them plus they make them down to 1"
dgage
chilly
Two reasons I've actually been considering those pads for long throw work.
JustJesus
Yup...
chilly
Where do you personally draw the long throw vs short throw dividing line?
I ask because I am considering a machine with a 12mm stroke and that number seems to really blur the lines
I think most people agree that a 9mm is short and a 15mm is long so there is a big middle ground
SDO’s would be what I would use. The Rupes duetto didn’t have the power that LHR 15 has so it’s not as violent.
JustJesus
Definitely! I seen the slo-mo video from LC showing that in action.
I see it when I use the SDO and HDO on my Rupes.
dgage
Yep, I'm that user.
chilly
lol
My Swirl Killer mini is a 12mm but a 3” it like the BOSS pads better than the lake country flats and CCS. I think it was due to pad being thinner just ran smoother.
Not sure if that helps on a bigger system but thought I’d throw that out there for the mini user’s
Coatingsarecrack
I agree. I’ve actually blown up a few LC Flats on my Mini Swirl Killer. The little Boss Pads seem to really benefit from the center cooling chamber. Plus I like the tapered edge.
I didn’t know you had a Mini Swirl Killer.
Eldorado2k
I use a SK Mini at work!
I use the 15 and the Mini and I actually, really enjoy using them.
