Do it right the first time - Dr. Beasley's 1201
It has been a long time since I have posted a question for the fine group of people here. I am a hobbyist and not a professional. I am getting ready to detail the daily driver for the summer. The car is less than a year old and I have taken care of it, so the paint is in really good shape except for a couple of spots. Here is the plan:
1. Wash
2. Decontamination with synthetic clay mitt
3. Wash
4. Correct a couple of areas
5. Black Fire Paint Cleaner
6. Dr. Beasley’s 1201
So here is the question. Will the Black Fire Paint Cleaner be okay before I apply the 1201? Should I do a step after the BF Paint Cleaner (I want to make sure the 1201 "bonds"? Should I skip the BF Paint Cleaner or use another product before I put the 1201 on?
I will be using a GG DA for the correction and the BF Paint Cleaner unless someone has a better suggestion.
Thanks in advance for the assistance.
Re: Do it right the first time - Dr. Beasley's 1201
#4 and #5 are actually similar steps due to product terminology confusion.
Paint cleansers are really polishes without much or any abrasives. They would be used as lubrication for a high polishing pad on paint that needs little to no correction.
What you actually need in step 5 is a panel wipe product such as Blackfire Paint Prep, Gyeon Prep, or CarPro Eraser. Or you could make up your own with isopropyl alcohol (IPA), I’m sure a recipe is on AGO somewhere.
I haven’t looked into 1201, but what do the instructions state? Does it require a panel wipe?
I believe it is a sealant and not so much a coating.
Thanks for the reply. The product is described as a nano-coating and the instructions do not mention a panel wipe prior to application.
Thanks again
There are a couple of areas that I will try the BF Paint Cleaner on first but I suspect I will need to polish out the two areas. I have IPA so I may just wipe down after the BF Paint cleaner.
Thanks again
From their site.
Last Post: 10-17-2020, 09:38 AM
By keninfl in forum Ask your detailing questions!
Last Post: 10-09-2020, 01:29 PM
By waterman in forum Auto Detailing 101
Last Post: 09-26-2020, 06:57 PM
By frankprozzoly in forum Auto Detailing 101
Last Post: 02-11-2019, 09:18 AM
By Beerwulf76 in forum Auto Detailing 101
Last Post: 08-04-2018, 10:21 PM
