Finishing advice / coatings
Hi Folks,
I'm just finishing 2 stages on a car that wasn't great but is now looking pretty good :-)
I'm planning to finish with Wolfgang deep gloss paint sealant BUT I'm wondering a few things and I'd be grateful for any thoughts:
1) Given the amount of work I've put in, would I be better using GTeqniq Crystal Serum Light or EXO? I'm concerned as I've never used these and wouldn't want to make a mess! Also, despite my efforts I haven't gone to the extent of removing badges etc. so that pain is not perfect and these coatings are fussy (I believe?).
2) If I stick with Wolfgang, I was thinking I could put a Carnauba over the top but given Wolfgang only lasts 4-6 months, I will want to use a quick detailer in between and will want to re-apply Wolfgang later - does this mean Carnauba would be a bad move? (not sure about QD over wax and also not sure about reapplying even though highly likely carnauba would wear off before 4 months).
3) has anyone re-applied Wolfgang? Is it as simple as a good clean and re-apply or does it require a fine cut first to remove any old product?
THANKS!
Ben
Re: Finishing advice / coatings
CSL and Exo are some of the most user friendly coatings. After all this work I would go the coating route.
Ben4 thanked for this post
Coating is the way to go without a doubt! The self cleaning properties alone are worth it on a big SUV like that
2022 Elantra N Cyber Gray
I would go coatings route. Recently used WG Profi and BF ceramic coatings; wen on easy ( make sure you do all the prep work ). Big SUV’s really take a lot of time so get a sealant that will give you a good 18 months ( my F150 is a chore, ceramic coated n good for 2 years,easily)
2022 Carrera S & Honda CRV Hybrid
2015 Lexus IS 350, 2016 Ford F-150
Cobalt 242 (8.1 L block, Volvo outdrive)
Originally Posted by
The Guz
OK, thanks. I just need to grow a pair the :-)
Will it be an issue that a) the paint isn’t perfect and b) I’ve not removed badges etc
Thanks. Think I’m going to do CSL with EXO over the top!
Ben4
Make the paint as nice as you possibly can, even if it takes a little more time. Remember the coating is sealing in what you just did, semi-permanent. As fas as the badges go, just clean around them good, maybe use your soft detailing brush, blow them out and coat right over them
Btw do you have a panel wipe to use before the coating application
If you enjoy the tinkering with products, then sealants and waxes are fine. Some people enjoy the Sunday morning wash & Wax routine.
If you would rather not be tinkering with sealants / waxes, and would prefer to be able to just wash the car and have it look great for longer periods of time, and / or need / want the increased protection, go with a coating.
Klasse Act
Actually that is a bit of an issue... I have some CarPro Eraser but I've read that I really need GTechniq Panel wipe as that is designed to completely strip the panel where eraser isn't. I REALLY don't want to make a mess with CSL, so I'm going to have to wait for the shops to open next week and get the G-panel wipe!
Do you think it'll be tricky to use CSL given I'm not taking badges off etc.?
Thanks!
