Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Newbie Member jlindyman's Avatar
    Dec 2020
    Tire coating prep for new tires
    New conti’s on my charger, going to use optimum tire coating on them.
    Washed and cleaned them with megs gold / Adams tire and rubber cleaner using drill bit brush, will wash and clean at least be more time prior to applying coating.
    How long should I wait before applying coating? Something about the new tire off gassing?
    Thanks for any advice!
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Re: Tire coating prep for new tires
    I don't think the tires release gases like a new interior does, but rather has a mold release agent that causes browning of the tires.
    I find Tuf Shine tire cleaner to work great. Keep scrubbing until the soap is white.
    Some say to wait a few weeks before cleaning and coating.
  3. Thanks jlindyman thanked for this post
    Likes Coatingsarecrack liked this post
  4. #3
    May 2013
    TN
    1,768
    What Rsurfer said.
    Tuf Shine Cleaner is good. Stoner’s Tarminaror is also a good one to use before a tire cleaner to reduce the number of cleanings. 303 Tire and Rubber Cleaner is supposed to be another strong tire cleaner. Realize that you might have to clean the tire 5-7+ times to get it not to turn brown. May want to clean the tire until it doesn’t turn brown, then wait 2 weeks and do it again, then apply the coating.
  5. Thanks jlindyman thanked for this post
  6. #4
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    I would clean them weekly until that mold wax release is completely gone. I never used that tire coating so I don't know how it reacts to any mold wax release still left. The Mckee's tire coating for example would turn brown. Not noticeable upon application but after a few miles drives. You could try some stoners tarminator as well after cleaning the tire.
  7. Thanks jlindyman thanked for this post
    Likes dgage liked this post
  8. #5
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    664
    Tuff shine helps. I throw everything I have at them. Full scrub, next. Full scrub, next. etc
    Usually there is a gummy type substance left that I wipe off with a solvent soaked rag. Then repeat above.
  9. Thanks jlindyman thanked for this post
    Likes Rsurfer liked this post
  10. #6
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    What I do when I coat tires is wipe them with a rag and some kerosene. (Really cuts through the crud) Then I follow up with a dedicated tire cleaner.
  11. #7
    Dec 2011
    Pompano Beach, Fl
    1,494
    I put on one of armourall’s coatings a couple years ago that was supposed to be one of their first coatings, and it was terrible …..it was splotchy it and flaked I don’t remember what it was called, I called armor all to complain and they agreed that it was probably reacting to something on the tire, I tried taking it off with kerosene and some other products, And it didn’t work …..I called them back and they said that I should use stoners Tarminator, it worked like a charm and brought me back to Virgin rubber.
    Glen -
  12. Thanks jlindyman thanked for this post
  13. #8
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by glen e View Post
    Are you talking about that Outlast spray coating? I tried that too and the results were a mess.
  14. #9
    Dec 2011
    Pompano Beach, Fl
    1,494
    Yes that’s it, terrible product, there wasn’t really anything on the wheel that I could tell that reacted with it , it was just a mess
    and although I don’t like things that don’t work properly, I REALLY don’t like things that don’t work properly and then turn semi permanent so that you can’t unwind it…The other one that comes to mind like that is the original recipe of carPro reload, a total cluster to get off after it went on splotchy…..
    Glen -
  15. #10
    Nov 2015
    13,765
    I never experienced that 1st batch of Reload, but I know exactly what you mean as far as that spray on coating.. Right about that same time there seemed to be several competing products such as Megs Ultimate Black Restorer in a spray can and that too was 1 of those products that turned semi permanent and was fairly easy to get wrong and if you did good luck trying to remove it. Friggin nightmare. Lol
  1. Will tire cleaner / coating prep remove wheel coating
    By Whitewater25 in forum Auto Detailing 101
    Last Post: 09-12-2019, 04:12 PM
  2. How To: Clean & Coat Your Tires with DP Tire Coating
    Last Post: 11-23-2015, 11:21 PM
  3. Tire Coating and New Tires
    By Rmd in forum Auto Detailing 101
    Last Post: 05-09-2015, 08:13 PM
