Re: Newby Asking for Polish Advice
The rule of thumb is begin with the least aggressive compound or polish and pad. Adjust both of the above until you achieve desired results
Sent from my SM-N986U using Tapatalk
Like Buster says, start with the least aggressive cut compound, better to be safe.
Also it will give you a chance to get to know the paint(hard/soft) as well as the in's and outs of curves and contours.
I personally would not use any of those.
That Toyota Black is pretty soft and don't see any of those finishing down without micro marring.
The 3m finesse II is a good product but more geared towards a rotary and is definitely not a finishing polish especially on soft Toyota black.
The 3m finesse II would be a medium cut.
Honestly I would give Turtle Wax Hybrid Solutions Ceramic Acrylic Polish Black a try. It is a VERY good product.
I am very much so NOT a fan of Meguiars compounds or polishes especially with so many much better products available these days.
What kind of correction are you looking for?
Are you looking to do a two step correction?
Ripping through your mind like a hurricane full of novocaine
Like the others have said, Toyota paint is VERY soft. This makes it very easy to correct...but also easy to swirl if you aren't careful.
I'm able to polish out our crimson Highlander using nothing but a finishing polish and a white Lake Country Flat or Thin Pro pad. I don't think I've ever had to use a compound other than to repair some scuff damage to a specific spot.
Products I've used to successfully polish out soft Toyota paint: Meguiars Ultimate Polish, DP Finishing Polish, Blackfire Polish, Optimum Hyper Polish, and Sonax 04-06. I would rank all of them equally except for the Meguiars. I found the gloss it created to not be as good as the others. The Optimum HyperPolish is the one I reach for most of the time when doing our Highlander.
I would start with a finishing polish for soft paint like that. Something like Griots Boss perfecting cream, or something like an AIO like the Finishing sealant. See how that does, maybe on a ruppes yellow pad (ive had great results with them) If that doesnt work, move to something a bit more aggressive. I cant see you needing anything more than a basic compound and a basic foam cutting pad (griots compound and orange pad are fine)
Like others said start least aggressive. If you want to stick with what you have start with the swirl remover on a polishing pad. That should cut the swirls just fine on softer paint. my .02
I've been looking at the Hyper polish for a while now. I keep thinking, "why no one else as this kind of polish...?"
I think i might give it a whirl.
In my opinion the weak link to the Hyper twins was always the sprayer, at least the 2 I bought, but that was years ago
I loved the product but it was expensive and I felt like half of it was wasted trying to adjust the nozzle and get it on the pad
My old PC is still a piece of abstract art from all the overspray
I think it was pink and blue
I had OPT send new sprayers and it took a couple to get through a bottle of product
I got to the point I was spritzing it directly on the panel to avoid waste
When you got it on the paint it worked and worked well
If i buy it i will probably mark the sprayer for the correction position and flush it with water after i was done polishing. Personally, its seems alot of sprayers are not the best in car detailing. Polish angels for instance is horrible.
I've never had a problem with the sprayer itself, but it does make for a very messy method of application. It is hard to not get all over the polisher and over sprayed onto other stuff.
Great polish. Messy method of delivery.
By 3Crowns in forum RV & Motorhome Detailing
Last Post: 03-29-2018, 04:57 PM
By BigBill in forum Auto Detailing 101
Last Post: 10-20-2014, 02:43 PM
By emanuel in forum Auto Detailing 101
Last Post: 09-28-2014, 08:10 AM
By italpasta in forum Auto Detailing 101
Last Post: 02-26-2008, 11:15 PM
By DannyM in forum Introduce Yourself
Last Post: 02-07-2008, 11:00 PM
25 | 26 | 27 | 28 | 29 |
