Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Junior Member ERS's Avatar
    Apr 2019
    Virginia
    39
    21 year old Mustang advice
    This past May I purchased a 1 owner, 87,000 mile 2000 Mustang GT. Original factory silver paint and does have some swirls. I've paint corrected my 2006 Black Mustang GT-H with great results. My question, with the GT's paint being 21 years old, is it risky to paint correct? I'm thinking the clear coat is expectedly thin at this point, and I do not want to take a chance of speeding up process of clear coat failure. Am I thinking correctly or should I go ahead and do it? Admittingly, the silver with the swirls is much more tolerable than the black. Thanks.
    Ernie
    Attached Thumbnails Attached Thumbnails 21 year old Mustang advice-img_e6973zz-jpg
    Super Member Bosko's Avatar
    Oct 2021
    Michigan
    1,584
    Re: 21 year old Mustang advice
    Imposible to answer without knowing the history of the car...I.E. how was it stored...how many times was it polished.
    You can get a paint gauge but IMO the are worthless without knowing what the depth was at delivery of the vehicle brand new.
    Many people are misdirected with paint depth gauges as they can't tell you how deep the clear coat is.
    They tell you primer/base/clear totals
    I'm no expert whatsoever with paint gauges, I hope someone that is chimes in, I'd like some further education myself
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Quote Originally Posted by Bosko View Post
    Not worthless if you know how to use them and how to measure.
    Under the hood on that Mustang is not cleared. Measure under the hood... probably going to read around 45 microns.
    Then take exterior measurements..... probably going to read around 115-125 microns.
    Take 120 microns (total paint thickness) and subtract 45 microns (uncleared paint measurement)
    120 - 45 = 75 microns of clear. (Very healthy clear)
    Most factory painted vehicles in the last 30 years will have around 45 microns of primer and base coat.
    If you measure 100 microns of total paint thickness polish away.
    A semi aggressive 2 stage correction that will remove most paint defects will only remove around 5-8 microns.
    Now you can't do that every spring but you absolutley can do that a few times during the life of the vehicle.
    Ripping through your mind like a hurricane full of novocaine
  4. Thanks opie thanked for this post
    Likes Bosko, Jayfro, opie liked this post
  5. #4
    Oct 2021
    Michigan
    1,584
    you are the first one to make more sense out of the matter...assuming the clear is as thick as you claim.
    Is there reference material to back up the claims as well as it a standard measure of ALL manufactures?
  6. #5
    Aug 2020
    Minnesota
    593
    On higher end foreign vehicles I find they do clear under the hood.
    Most American vehicles do not clear under the hood and a lot of mainstream foreign vehicles do not clear under the hood.
    I do find total paint thickness on foreign vehicles to be around 90-105 microns and America vehicle's to be 100-125 microns with both measuring similar under the hood but foreign under hood being a bit thinner but also looks like it lays down better.
    So on a foreign vehicle if under hood is 35 microns and total paint thickness being 90 microns that's so 60 microns of estimate clear and considered healthy.
    Door jams are also another place to measure with limited clear being sprayed here and I usually find it to be about 20 microns more than under the hood.
    So what I do is measure under the hood (40 microns)
    Door jams (60 microns)
    Total paint (100 microns)
    Then I take the under hood measurements and add to jam measurements and divide by 2.
    40 + 60=100 ÷2 = 50 microns
    Than I take my total paint measurements and subtract 50 microns (bare minimum bottom with primer, base and clear)
    100 - 50 = 50 microns of clear
    That was a bit of rambling post there but hope it kinda answers your question.
  7. Thanks JDGolden thanked for this post
    Likes Bosko, dgage, JDGolden liked this post
  8. #6
    Feb 2012
    Palatine Illinois, USA
    24,496
    Test spot with an orange pad, medium speed and an AIO and go from there21 year old Mustang adviceI'm subscribed because I wanna see how this turns out...real car, real owner and real results coming21 year old Mustang advice
    2022 Elantra N Cyber Gray
  9. Likes Bosko liked this post
  10. #7
    Oct 2021
    Michigan
    1,584
    Thanks 98...educated on Thanksgiving!
  11. #8
    Jan 2015
    Simi Valley, CA
    1,783
    98CayenneTA's explanation of how to use a PTG is the best explanation I've heard.
    That said, there will always be some subjectivity in whatever conclusions you reach from the measurements.
    Personally, I've never felt the need for a PTG.
  12. #9
    Oct 2021
    Michigan
    1,584
    Quote Originally Posted by 2black1s View Post
    how many times you polish dat chevey?
  13. #10
    Jan 2015
    Simi Valley, CA
    1,783
    I'd guess 10-12 times. It's 6 years old and I've done it probably twice a year. The first polishing when it was brand new was with a rotary/wool followed by a DA/foam. Since it's always been a DA/foam.
    Mind you, other than the first polishing, it has always been very light polishings as it is well cared for and never needs any serious correction. I'm a little over-the-top-crazy. Whenever I start to see even the slightest of swirling/marring, I'll polish it.
  1. Seeking Advice on 28 year old car
    By readthebook in forum Auto Detailing 101
    Last Post: 06-04-2018, 09:55 AM
  2. Replies: 3
    Last Post: 03-10-2017, 05:17 PM
  3. What year is this Ford Mustang?
    By alpha1 in forum Off-Topic
    Last Post: 06-21-2015, 08:46 PM
  4. Replies: 32
    Last Post: 01-07-2013, 08:36 PM
  5. Mustang first year made w/180wax
    By HighEndDetail in forum Show N' Shine
    Last Post: 06-26-2007, 08:58 PM
