Results 1 to 4 of 4
    Apr 2014
    WI
    125
    Blasted AC spec sticker off - how to stick it back?
    I was pressure washing the engine bay on my Renegade a few weekends ago and blew the AC spec sticker off the fan shroud. What kind of adhesive should I use to reattach it?
    Thanks!
    17 Land Rover Discovery: Fuji White; 07 Land Rover LR3 SEV8 4WD: Java Black Micatallic; 18 Jeep Wrangler JLU Sahara: Black; 05 Jeep Liberty Limited 4WD: Light Khaki Metallic
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Blasted AC spec sticker off - how to stick it back?
    My first thought would be to check with your Jeep parts guy at the dealership and have him order you a new one.
    If they are unavailable, I would then try 3M spray adhesive. It is some really good stuff.
    Mar 2011
    PA
    5,792
    2018 Colorado ZR2
    Aug 2015
    Andover, MN
    1,727
    +1 for Paul's just get a new one. Most of the underhood stickers on the cars I work on have a part number on them, you could look it up that way.
    As someone who uses that sticker as part of their job, honestly you could also just stick it in with your owner's manual and skip having it underhood. You only need the sticker when servicing the A/C, so if you knew it was going to be worked on you could provide it to whomever is doing the work.
  1. Front of car looks like it is sand blasted
    By asalesagent912 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 07-10-2012, 10:03 PM
  2. Replies: 6
    Last Post: 06-26-2011, 09:39 PM
  3. How do I spec a trailer?
    By krzdimond in forum Auto Detailing 101
    Last Post: 05-26-2009, 04:44 PM
  4. micro sand blasted frontend...
    By vinnier6 in forum Auto Detailing 101
    Last Post: 03-27-2008, 01:24 PM
  5. R34 GTR V-Spec
    By Bobjones in forum Show N' Shine
    Last Post: 07-19-2007, 03:27 AM
