Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
Thread: Layering?
  1. #31
    Super Member Loach's Avatar
    May 2014
    Florida
    421
    Re: Layering?
    On two separate cars after correction and panel wipe, two applications of Gyeon Wax were significantly more effective in showcasing its coating level hydrophobics compared to one application, it was a night and day difference for those cars. Even guaranteeing full and thorough coverage on the first application, there are times when things just don't stick as well or other factors are coming into play. The same thing with something like Meguiar's Hybrid Ceramic Wax, some paint out there just needs a few applications to get this product going to a high level. I also saw a stacking effect after two applications of Ultimate Quik Wax on the test panel.
    This is one of those topics where your mileage may vary.
  2. Thanks Klasse Act, NJNinja thanked for this post
    Likes Klasse Act, NJNinja, dwaleke liked this post
  3. #32
    Aug 2019
    566
    Re: Layering?
    Loach, I applied GG 3 in 1 on the heavier side this time and it really boosted the water repellency quite a bit. They recommend 2 layers, 12-24 hours apart but I did one single heavier layer. I think layering the same product with same chemistry can be beneficial, but there will be diminishing returns at some point and possibly losses.
    GG 3 in 1 isn't know to be the best "beader" but I have to say after applying it heavy it is on the same level as HCD etc.
    Griot's 3 in 1 Ceramic - YouTube
    GG 3 in 1 - YouTube
  4. #33
    Jan 2015
    Simi Valley, CA
    1,387
    Re: Layering?
    I think the biggest benefit to layering products is the psychological effect of feeling like you have done a "better" job.
    The reason I say that is because my primary measure of effectiveness and objective for any LSP is how good does it look. Water behavior, longevity and other measures are secondary to me.
    I have on occasion applied a second coat of whatever product I'm using to a small section that has already been completed... And I have never been able to see a difference. It's for that reason I believe the benefits of layering to be primarily psychological.
    That said, I'll admit to applying two coats of the same LSP from time-to-time. It gives me the psychological "feel good" benefit.
    Let me also say that my perspective is as it relates to waxes and sealants. Coatings are not a part of my vocabulary and I do understand that they may very well be a different animal.
  5. Likes NJNinja, Klasse Act, chilly liked this post
  6. #34
    Super Member chilly's Avatar
    May 2006
    Hawaii
    212
    Re: Layering?
    Maybe we need to be using more than one mindset here, and I am not saying some of us aren't
    Maybe we need to discuss "layering" as it refers to applying multiple layers of the SAME product and separately discuss "topping" or "stacking" (I like that term by the way) or some other term to discuss putting multiple DISSIMILAR products one on top of each other in an attempt to reach an objective
    It just seems like we are having an apples and oranges discussion here at times
    Just thinking out loud
  7. Thanks Klasse Act, NJNinja thanked for this post
    Likes Klasse Act, NJNinja liked this post
  8. #35
    Aug 2019
    566
    Re: Layering?
    Great point chilly. That is very true.
    My thoughts are (I'm not expert just thinking here): Wax over a sealant is not a problem. Wax over wax may or may not work. The new layer of wax can remove the already existing layer.
    Then you have instances when you top or stack different products. That is something I wouldn't be in favor of unless the chemistry or products were meant to work together. I know Meguiars specifically states that their entire line of Hybrid Ceramic is compatible with one another.
    You see instances where people that have good coatings layer something on top, only to find it diminishes the performance level of the coating.
    I'm sure there is no harm in mixing, but from a chemical perspective I'm not sure how ideal that is.
  9. Thanks chilly thanked for this post
    Likes chilly, Klasse Act liked this post
  10. #36
    May 2006
    Hawaii
    212
    Re: Layering?
    Quote Originally Posted by NJNinja View Post
    ^^^^ This ^^^^
    Layering?
  11. #37
    Mar 2017
    Southeastern PA
    2,118
    Re: Layering?
    Quote Originally Posted by chilly View Post
    Good point. The entire time I was thinking about topping and not layering more of the same product. Perhaps if layering really is the initial question, then I tend to just follow the manufacturer's instructions. If it calls for more than one layer, I do that. If it calls for a single one, I do just that. You'd think the manufacturer knows how well their product will bond to itself and if it's even necessary. I remember the only coating I've done that was a single layer was McKee's and they were pretty clear saying to use just one layer. The others all have called for more than one and that's what I did. The ones that said at least 2, but 3 can also be done, like Mohs, I only did 2. I'm all about less work.
    Bruno Soares
  12. Thanks chilly thanked for this post
    Likes chilly, NJNinja liked this post
  13. #38
    May 2006
    Hawaii
    212
    Re: Layering?
    I think a lot of the information we are thinking about and working from is dated
    The days of DuPont number 7 car wax with a cleaner built in are gone, thankfully, but the dogma associated with it lives on
    That stuff was just short of toxic and there is no way layering it left anything from the previous layer
    But I just watched a video of the new Gyeon Wax (which I wasn’t really aware of) and we are back to apples and oranges
    They are both “waxes” but other than the name I don’t see them as remotely the same product and I can easily see Gyeon Wax building with more applications
    I keep going back to 3D Speed and Poxy
    They were purpose built to complement each other and although they both contain wax I seriously doubt a layer of Poxy takes off the previous small amount of protection left by Speed
  14. Likes NJNinja liked this post
  15. #39
    May 2006
    Hawaii
    212
    Re: Layering?
    Quote Originally Posted by Bruno Soares View Post
    You follow the instructions?
    Layering?
    Turn in your man card immediately
    Next you will be using maps and asking for directions…
  16. #40
    May 2006
    Hawaii
    212
    Re: Layering?
    Sorry, it slipped out
    Your point is well taken
    The chemists know more than we ever will
    I enjoy tinkering as much as the next guy but sometimes it’s just not productive
  17. Likes NJNinja liked this post
  1. ONR in between layering
    By jerelect in forum Auto Detailing 101
    Last Post: 05-07-2012, 10:37 AM
  2. Layering?
    By Dadillac in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-08-2012, 07:37 PM
  3. layering nxt 2.0
    By corolla619 in forum Ask Mike Phillips your detailing questions!
    Last Post: 10-29-2010, 10:23 PM
  4. Layering
    By tiger 6 in forum Auto Detailing 101
    Last Post: 01-23-2008, 03:57 AM
  5. Layering
    By Bill-SD in forum Pinnacle Wax
    Last Post: 12-21-2007, 12:03 AM
Members who have read this thread: 63
» September 2021
293031 1 2 3 4
26 27 28 29 30 12
