Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Mar 2006
    Claying question and iron remover
    I want to clay my car before winter sets in and was wondering if I am going to clay it do I need to use an iron remover. I thought that is what claying was for.
    SELF BANNED
    Jun 2019
    1,076
    Re: Claying question and iron remover
    Quote Originally Posted by tasdisr View Post
    I used an iron remover last week on my fathers white rogue it was littered with these little rust spots which the iron remover turned purple and most where rinsed off but a few days prior to that i just used the clay, it took twice as long to get all the little rust spots off with clay only.
    I detailed the car in sections. It was my first real good experience with an iron remover on paint work.
    Mar 2006
    What iron remover did you use? I was thinking of trying Griots.
    SELF BANNED
    Jun 2019
    1,076
    I used a brand that i don't think autogeek sells, i'm sure Griots would work. Carpro's ironx is another popular option.
    Dec 2018
    7,170
    I’ve tried Griots, Gyeon, Meguiars ultimate wheel, CP Iron X, Eagle one black and plast dip and Black Fire.
    All worked pretty much the same. The two tire cleaners (both iron color change) worked fine too. I now buy what’s on sale.
    The Griots and BF are nice as they are gel’ish and seem to cling better. Don’t know if that’s better but i like it
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    I use both products before paint correction. Iron Remover will help dissolve ferrous contaminants and the Clay Bar will help pull embedded contaminants from the paint surface.
    BLACKFIRE Iron Remover
    BLACKFIRE Poly Clay Fine Grade
    Super Member 2wookies's Avatar
    Jul 2015
    367
    Best practice is Iron remover first, then a tar remover on the lower sections rinse and then clay entire vehicle. Thats if you want that perfect prep for the surface, just remember this will pull any sealant or wax off the vehicle.
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by noorth View Post
    So you’re saying the clay got all the rust spots off but took twice as long?
    You also say the iron remover got the rust spots off and they rinsed away? Please clarify.
    SELF BANNED
    Jun 2019
    1,076
    I found the iron remover really helped to remove this light looking rust spots. I assume its iron or something. T
    They were all over certain sections of the car. I used a fine clay and they would come off relatively quickly but when i broke out the iron remover it certainty got rid of a lot of the little spots before i put the clay back on the paint.
    I used iron remover on my blue car few times before and i never seen a difference only wheels.
  10. #10
    Nov 2015
    13,765
    Did you notice a difference with the iron remover in the sections you used the clay beforehand? Was there still iron that needed removing? Or had the clay pretty much removed it all?
  1. Replies: 6
    Last Post: 03-09-2020, 06:31 PM
  2. Dumb question on using iron remover for first time
    By ejaf in forum Auto Detailing 101
    Last Post: 06-06-2019, 12:36 PM
  3. McKees 37 iron remover question
    By Richs66 in forum Auto Detailing 101
    Last Post: 05-13-2018, 02:03 AM
  4. Rusted Cast Iron / Iron X / Iron remover
    By Swift in forum Off-Topic
    Last Post: 01-19-2018, 09:23 AM
  5. Iron remover, Claying, Optimum No Rinse and Sealant?
    By BuffaloBill in forum Auto Detailing 101
    Last Post: 11-26-2015, 05:42 AM
