Using heat gun to remove rubber marks from paint?
Anyone here use a heat gun when removing rubber marks from paint? (rubber marks like from tires when tracking a car, burnouts, etc).
Does it work? If so, what's your technique and about how hot do you get the paint (80 degrees F, 90, 120...?).
Bonus questions:
- Any other techniques for removing the rubber that people think are better/safer ?
- Anyone know the science behind using a heat gun to remove the rubber marks?
Re: Using heat gun to remove rubber marks from paint?
Yeah you want to remove it with a chemical, not heat…try an acetone or alcohol wipe, don’t dwell…..
and next time use trak wrap behind the wheels -off Amazon…..
I keep one of these on hand all the time- this is what body shops use to remove decals, pin striping
It might work for you
https://www.amazon.com/ABN-Rubber-Er...28562227&psc=1
Originally Posted by
Eldorado2k
That has solvents in it though (albeit likely very diluted).
I'm not against solvents, but maybe heat is a better option. Not sure.
Also, that R3 seems to have great reviews.
glen e
I have heard good things about trak wrap.
I’ve used that R3 on my track car many times to remove a lot of race rubber. I think it works as advertised, and would recommend.
