Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 54
  1. #21
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    Re: Rupes Recommended Method for Pad Priming
    Quote Originally Posted by 2black1s View Post
    - No one uses a new pad for every section
    I don't know anyone who uses a new pad on every section either. But I always use 4-5 on every car. They are not all "NEW" but most are used pads that I re use after I cleaned and dried them after using them on a prior job.
    I dont blow my pads out with air- I use a brush mostly and sometimes the white terry cloth. I just dont trust my air to be 100% pure & oil free and would worry about a minuscule amount of compressor oil contaminating my pads.
    I have had excellent results in the past so I will keep with my method of cleaning. I guess I need to get a SUPER good oil/water separator on my A/C, right now I have nothing.
  2. Likes PaulMys, chilly liked this post
  3. #22
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by luckydawg View Post
    I will use a new (previously used & cleaned) pad on every panel (2 for bigger panels).
    But I just start them out with tried & true "circle of product" each time, and I have never had one problem.
  4. Likes luckydawg, chilly liked this post
  5. #23
    Jan 2016
    1,117
    I usually change out pads every other panel to every panel & 1/2
  6. Likes chilly liked this post
  7. #24
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,737
    So much good info here
    I am also glad I’m not the only one scratching his head over this nonsense
    I think the common thread here is we are all focused on results and a “professional” level finish whether we are getting paid or not
    How we get there may differ but if there was only one pad, one machine, one method, how boring would that be
    Thanks everyone for your considered and valued input
    Now I will get back to concentrating on the gorgeous young lady doing my pedicure, or as I call it, “foot correction and coating”…
    Peace
  8. #25
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Quote Originally Posted by chilly View Post
    Peace
    talk about being retired and pampered.
  9. Likes PaulMys, chilly liked this post
  10. #26
    May 2013
    TN
    1,768
    I know. I was right with him…until his last comment. Lol!
  11. Likes chilly liked this post
  12. #27
    May 2006
    Alaska
    1,737
    Could it be the compound that he's using and it's not breaking down causing some haze?
    I can’t find anything that says if Jescar Correcting Compound is a diminishing abrasive or not
    If you do the same number of passes with the all same variables EXCEPT for the quantity of product will that make a difference in how long it takes the product to break down, assuming it is a diminishing abrasive?
  13. #28
    Jan 2007
    14,093
    Diminishing abrasives won't diminish completely in two passes.
  14. Likes chilly liked this post
  15. #29
    May 2006
    Alaska
    1,737
    Might as well go for broke while I have a captive audience
    Probably a simplistic question with multiple answers but here goes
    If i understood Tunch Goren of 3D correctly on a video the difference in a compound and polish isn’t necessarily the size of the abrasives, it can be the quantity of abrasive grains in a given volume of liquid or both
    Does that sound accurate?
  16. #30
    May 2006
    Alaska
    1,737
    Quote Originally Posted by dgage View Post
    Don't judge me...
    lol
  17. Likes dgage liked this post
  1. Replies: 3
    Last Post: 10-19-2018, 07:43 AM
  2. Rupes new wool pads priming
    By ARTB155 in forum RUPES BigFoot Oribital Polishers
    Last Post: 03-26-2018, 02:04 PM
  3. Wolfgang Uber coating - Priming and post priming
    By emmjay in forum Ask your detailing questions!
    Last Post: 09-04-2016, 06:11 AM
  4. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  5. KB Method...Priming the pad....Seems a little backwards to me?
    By Rez90 in forum Ask your detailing questions!
    Last Post: 03-23-2011, 10:36 AM
