Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 54
    SELF BANNED
    Jun 2019
    1,076
    Re: Rupes Recommended Method for Pad Priming
    Quote Originally Posted by Bruno Soares View Post
    I don’t think it’s too risky at speed 2 like they recommend but I’ve never done it myself. I don’t prime foam pads anymore, I just put a little more product on the first go. I do prime microfiber pads though.
    Basically what i do. The first application i will put more then usual on the pad and the few times i used microfiber i primed it - i 1 step mostly so i don't use microfiber very often. Just seems like the logical thing to do with microfiber. Hundreds of successful detailers i'd imagine that don't prime foam pads. While the gloss i got from rupes DA fine and yellow foam pad is very good it doesn't have a very long working time. Rupes seems to be creating a very rigid system. Not my thing personally. I like to use my own imagination and intuition more then that. Back to 3D One, again.
    Speed 2 shouldn't be risky i don't think.
  2. Likes chilly liked this post
  3. #12
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,764
    I figured since we had already kicked this topic around I would post here
    I have a feeling I must not have been the only one to question his methods
    Almost 20 minutes on priming vs not priming
    DEBUNKING pad priming, with SCIENCE! - YouTube
    His conclusion is MORE hazing/micro marring from priming...
  4. #13
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    I saw that video. I will stick the manufacturers pad priming recommendations rather than this method. Those gloss meters are nice but it is still flawed as it is not always the same number even placed in the same area. It is not like the pad is being primed every pass so no excess product is wasted.
  5. Likes chilly, luckydawg liked this post
  6. #14
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    And since you don't change pads after every panel, eventually your non primed pad will be primed.
  7. Likes chilly, The Guz liked this post
  8. #15
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    Personally I believe the manufactures of products know what they are talking about 99.999999999999999999999999% ( you get the idea here ) of the time. The reason is to generate a LITTLE heat to make the pad more flexible / workable. Wouldn't generate enough heat to do any damage.
  9. Likes The Guz, PaulMys, chilly liked this post
  10. #16
    May 2006
    Alaska
    1,764
    I’m struggling with how to say this
    What you guys say is true
    As we add section passes to a pad we add product and it get wetter and more full of product as well as residue
    Even if we blow it or brush it out each pass we eventually reach the point of saturation in product AS WELL AS RESIDUE
    If blowing and brushing was enough to get rid of it all we could do a car with 1 pad
    I think we all know that the residue that builds up is responsible for a lot of the micro marring and haziness we can get
    Pretty sure that’s a given
    I just can’t for the life of me see how Todd can get hazing with a clean pad, all variables the same, just a difference in amount of product
    The pad can’t pick up enough residue in 1 section pass to account for the haziness shown in that video
    I know I’m beating a dead horse but I’m struggling to understand how he’s getting this result
  11. #17
    Jan 2007
    14,094
    Quote Originally Posted by chilly View Post
    Could it be the compound that he's using and it's not breaking down causing some haze?
  12. Likes chilly liked this post
  13. #18
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    I wouldn't waste time trying to understand nonsense. I have never experienced anything like this.
    Any Yahoo can make a video and spin it any way they please........
  14. Likes chilly liked this post
  15. #19
    Super Member Dan Tran's Avatar
    Sep 2015
    Portsmouth, NH
    1,055
    I am very glad that I am not the only one who feels this way. I respect all these professionals and their contribution to the detailing industry.
    I personally have experience with RUPES DA System and a lot more with Todd’s approach to paint correction…
    Currently, I prefer using Jescar Correcting Compound / Meguiar’s Microfiber Cutting Disc and Sonax Perfect Finish / RUPES DA Fine Foam Pad as my main go to.
    I am very proficient with both approach / systems but the one factor that I have been battling with for over a year has been the idea of priming vs. no priming.
    I don’t care for the RUPES priming method as I too think that with an inexperienced person, it can be risky. Are we assuming that everyone has a paint depth gauge? Long throw machines has a lot of action happening. Let’s not forget that.
    While I can’t speak for everyone, I think we all can agree that achieving a fine finish from the compounding step alone is the best case scenario. Yet at the same time, knocking out light hazing with the polishing step is not difficult to accomplish either.
    Currently, I prime all my pads according to the conventional method we all know of. However, I do blow my pads out after with a tornador air gun. But instead of loading up with 3 drops of product, I load up with literally a pea size drop. That is all.
    As a side note, I am a low, low speed type of guy who uses the washer mod in case anyone is wondering…
    My procedure continues as usual, blow out the pad every few cycles and load up again with one drop of product.
    At the end of the day—as long as I, the professional am satisfied with the results I see, then I have a lot of confidence that my clients will be happy.
    KISS. Don’t over think it. The end goal it to get rid of defects.
  16. Thanks PaulMys thanked for this post
    Likes 2black1s, chilly liked this post
  17. #20
    Jan 2015
    Simi Valley, CA
    1,783
    I watched the video and wrote a thorough, 5 or 6 paragraph response earlier today. When I tried to post it I got logged out and lost it.
    I'm not going to try to rewrite it but the main points were as follows:
    - The design of any test can have a major influence on the results
    - The test depicted doesn't replicate real world conditions very accurately
    - No one uses a new pad for every section
    - The amount of product used for the two test sections varied widely
    In the end, as far as detailing is concerned, the bottom line is results. How you get there is irrelevant as long as your process delivers the results you want and expect.
    It's not rocket science.
  18. Thanks PaulMys thanked for this post
    Likes Dan Tran, chilly liked this post
  1. Replies: 3
    Last Post: 10-19-2018, 07:43 AM
  2. Rupes new wool pads priming
    By ARTB155 in forum RUPES BigFoot Oribital Polishers
    Last Post: 03-26-2018, 02:04 PM
  3. Wolfgang Uber coating - Priming and post priming
    By emmjay in forum Ask your detailing questions!
    Last Post: 09-04-2016, 06:11 AM
  4. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  5. KB Method...Priming the pad....Seems a little backwards to me?
    By Rez90 in forum Ask your detailing questions!
    Last Post: 03-23-2011, 10:36 AM
