Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
    Apr 2021
    Mojave Desert of Southern California
    43
    Blackfire AIO plan
    I have read here every day and night for days. I'm hoping for confirmation on my plan of attack.
    2013 Black 4Runner
    Always waxed, but very water spotted.
    Garaged, driven 3 times/week. 1 mile of dirt road between garage and pavement.
    2 bucket wash, blow dry.
    Already purchased and plan on using:
    Meguiar's clay and lube., including glass
    Supa Beast
    BF One Step using Lake Country Hybrid pads. Test with white, orange if necessary. If I need the orange, then follow up with another round of one step.
    If so, white or black for second round of One Step?
    BF BlackICE Hybrid Liquid Wax using LC Hybrid red pads.
    I've read wait 24 hours between the One Step and the Wax. I've also read it's ok to apply after an hour. Thoughts?
    Also bought Sonax PNS for the hood. Is there a cure time before adding this on top of the wax?
    I'm a microfiber addict. Have thick Cobras, Edgeless Cobras, and a lot in between. Think I'm good on towels.
    Have pad cleaners, brushes, terry towels, microfiber cleaners, washing machine cleaner.
    Have not bought or used a chemical decontaminant. I'm guessing I shouldn't skip this step?
    Thanks for any advice. I read a bunch before choosing these products.
  2. Likes Goonie75 liked this post
  3. #2
    Super Member Goonie75's Avatar
    Feb 2017
    696
    Re: Blackfire AIO plan
    Quote Originally Posted by Burger View Post
    2013 Black 4Runner
    Supa Beast
    Sounds pretty good. I do like the chemical decontamination myself. Just pops more. And if you're using an AIO, it will leave a protective layer behind. Not a long lasting one but will nonetheless. Putting a wax on that means the wax is bonding to the AIO protectant technically and not the paint itself. One can do it, but might not have the longevity.
    Also, an AIO typically means going around once... can go around more, but then its a 1 step or 2 step and might as well use a good polish. Idk.... just a thought.
    If you do polish instead of AIO, I find, although not necessary, that a panel wipe like eraser, does all that much better in allowing the topper to bond better to paint and not the polish oils.
    Good luck
    Ryan
    Sent from my SM-G965U using Autogeekonline mobile app
  4. Likes Bruno Soares, robwoodgto liked this post
  5. #3
    Dec 2011
    Pompano Beach, Fl
    1,494
    I agree, I think you want a polish instead of an AIO if you’re going to follow it with the hybrid wax.
    Glen -
  6. Likes Goonie75 liked this post
  7. #4
    Feb 2017
    696
    HD One is a pretty good product for this sort of thing.
  8. Likes Prange liked this post
  9. #5
    Dec 2012
    Fl.
    290
    I use blackfire one step.....it cleans...polishes...protects.....and if you want to you can top it with Blackfire SIO2 sealant a good combo
  10. Likes Bruno Soares liked this post
  11. #6
    Mar 2017
    Southeastern PA
    2,480
    You’ll be fine with just one pass. If the paint is soft, white pad will do it. If it’s medium or hard, orange will finish well enough to be done. When using an AIO you’re looking for enhancement and not perfection. Wait a few weeks for the wax in the AIO to start diminishing and then apply the other wax/sealant you wanted to top it with.
    Bruno Soares
  12. Likes PaulMys liked this post
  13. #7
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    I have never worried about topping an AIO. I do it all the time with no ill effects.
    Also, unless your paint is super soft, you might be pleasantly surprised at how well BF One Step finishes down with LC Orange pads. I'll be willing to bet that you will not need a second "go-round" with another pad.
  14. Likes Bruno Soares liked this post
  15. #8
    Regular Member crg001's Avatar
    Oct 2020
    Redlands CA
    171
    Blackfire One Step is a joy to use. It has good working time, so if you are aiming for a bit more correction, you can do multiple passes without it drying out on you. I like to do a test spot first to make sure my process has enough correction for my goals. I would only use "One Step" of polishing with this stuff. An orange pad may be necessary to cut through the water spots you have, but test the white pad first. Black Toyota paint is pretty soft, so always start with the least aggressive method.
    You can do a small section with 2-4 passes and wipe it off immediately and inspect with a good light to see if it is getting the results you want. After you dial in which pad works best, go around the entire vehicle with it before wiping it off. This gives it time to bond with the paint well, as well as makes it even easier to wipe off.
    At this point, it's had enough time to set and can be topped with the Blackfire hybrid wax immediately. With this you will also want to go around the entire vehicle, give it time to bond to the paint, and then wipe it off. Anything else on top of that would be best to do after 12-24 hours.
    Good luck, you will enjoy using these products!
    Colin Lang
    @DimensionalShine <- My Detailing IG Page
  16. #9
    That'll work. My guess is the white pads with the Supa BEAST will be more then enough. If this is a daily driver, that's all I would do. I wouldn't use the orange cutting pads and aim for 100% defect removal as I would rather get good results, not show car results and preserve the clearcoat. Again there's a difference between doing show car work and daily drivers.
    I don't wait at all. As soon as I've wiped of the BF One Step I machine apply the BlackIce.
    Not really. My guess is the act of RUBBING the PNS over the paint that has been finished with BF One Step and whatever carrying agents are used in the PNS will remove whatever BF One Step is on the surface and replace it with the PNS.
    So no waiting - just apply.
    I used to use iron remover, fallout removers before every wash. Then after Autogeek was sold to Vision Investments, out of the blue the fine print in the lease agreement that stated we could not wash cars outside started getting enforced, thus the reason you see me washing cars inside the garage, not outside.
    Since then I stopped using iron removers. But for what it's worth - I've seen iron removers stain anodized aluminum trim. It's incredibly difficult to do ANY type of restoration work on anodized aluminum. I've fixed it using BLACKFIRE One Step with a microfiber pad on the RUPES Nano in rotary mode - but I don't ever want to do it again.
    So yeah... I just stopped using these types of products - for now.
  17. Likes Kamakaz1961, Prange liked this post
  18. #10
    Apr 2021
    43
    Thanks everyone for your input. I'm excited to pull my 4Runner in the shop and enjoy taking my time doing the whole thing.
    And Mike, I was looking for a reason to not use an iron remover...cool!
    This time I will take before and after pics.
    Glanced at TapaTalk for posting pictures, but haven't gotten into it yet. If I'm going the TapaTalk route, I should take pics with my phone, and not a dedicated camera...yes?
  1. Replies: 11
    Last Post: 07-28-2020, 08:20 AM
  2. Blackfire One Step + Blackfire Paint sealant
    By Monster42 in forum Auto Detailing 101
    Last Post: 05-28-2020, 03:44 PM
  3. Blackfire Wet Diamond vs. Blackfire Crystal Seal
    By Jmoran in forum Auto Detailing 101
    Last Post: 12-17-2015, 03:17 PM
  4. BLACKFIRE BOGO Event! 34 BLACKFIRE Products are Buy One, Get One FREE!
    By Nick McKees37 in forum Blackfire Wax Products
    Last Post: 11-23-2015, 08:21 PM
  5. Plan A or B?
    By NoleFan in forum Auto Detailing 101
    Last Post: 12-07-2011, 04:06 PM
