Results 1 to 6 of 6
    May 2008
    46
    Average depth of light swirl marks?
    What's the approximate depth of light swirling? Just after a very approximate value. Reason for asking is that Apex have just released a video about machine polishing swirl marks out of a coating. (I'm sceptical)
  2. Likes Jacob Harrod AUTOCLEAN liked this post
  3. #2
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Re: Average depth of light swirl marks?
    1-3 microns I consider light damage
    25.4 microns = .001"
    25.4 microns = 1 mill (one millionth of a meter)
    Ripping through your mind like a hurricane full of novocaine
  4. Likes Jacob Harrod AUTOCLEAN liked this post
  5. #3
    Interesting.
    So many variables for something like this? For example, how thick is the coating to be polished in the first place?
    I have not watched the video but more power to him.
  6. Likes Jacob Harrod AUTOCLEAN liked this post
  7. #4
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by Skip View Post
    •In that case:
    -I’ll say that, IMO, it can’t be much more
    than somewhere ~1μm. Any more than
    that, and you’ll be going into the paint
    system’s topmost film-coat—ie: the CC.
    •Either way (again IMO):
    -The Coating has been compromised in the
    area where the buffing occurred; and needs
    to be repaired/replaced [via the Manufacturer’s
    recommended process(es)] in order for it to
    be made whole once again.
  8. #5
    Aug 2020
    Minnesota
    593
    I just watched the video and I did not take it as being able to correct a coating only.....
    To me it looked like he was showing what he would do on a coated panel that has accumulated light to medium damage.
    Just going the absolute bare minimum to remove the damage with a combination of Essence, Essence Plus & Angle wax polish with a no cut foam pad then doing a ipa and he re-coated the panel.
    It really does not take much to remove a coating by machine.
    If ya want to see just put a test spot on one of your windows but don't wipe it off, leave it as a high spot. I say window because coating high spots stick out like a sore thumb on glass, then see what it takes to remove it.
  9. #6
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    I watched the video and found it hard to watch. Just as Mike mentioned there is no way to know the coating thickness and no real way to gauge the defects are in the coating or paint. Coatings are not that difficult to remove. Any abrasive polish will remove it and also taking into account the cut of the pad. He shows using essence and even that will remove a coating along with a polishing or finishing pad.
    I do questions some of the things he does.
  10. Thanks BudgetPlan1 thanked for this post
    Likes BudgetPlan1, PaulMys, JustJesus, dwaleke liked this post
  1. Replies: 8
    Last Post: 08-20-2018, 06:17 AM
  2. Replies: 1
    Last Post: 10-18-2017, 11:40 AM
  3. Removing Light Swirl Marks on GelCoat
    By davewfo in forum Boat & Marine Craft Detailing
    Last Post: 04-27-2017, 11:49 AM
  4. Best light to spot swirl marks.
    By Roikins in forum Auto Detailing 101
    Last Post: 11-02-2014, 04:42 AM
  5. Swirl Marks
    By okcreferee in forum Auto Detailing 101
    Last Post: 05-07-2014, 06:34 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
