Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Mar 2014
    Melbourne, Florida
    232
    Is it possible to clean with just a foam cannon soak and rinse?
    I just polished out my 2014 silver Subaru Impreza with 3D Speed and a week later I topped it with a coat of FK1000P. The paint is nice and slick. I've never used a Foam Cannon before but could I get away with just soaking the car in foam and letting it dwell for a short time and then rinse it or do I still need to do a 2BM wash? I don't understand the need for a foam cannon if you still have to do 2BM.
    This car is my DD that sits outside 24/7 on the Space Coast of Florida.
    I'd really like to maintain this finish as long as possible with a method that is quick and easy.
    Feb 2012
    Palatine Illinois, USA
    24,529
    Re: Is it possible to clean with just a foam cannon soak and rinse?
    When my car is just dusty/pollen I do this very thing w/o a problemIs it possible to clean with just a foam cannon soak and rinse?Is it possible to clean with just a foam cannon soak and rinse?Is it possible to clean with just a foam cannon soak and rinse?
    2022 Elantra N Cyber Gray
  3. Likes jem7sk liked this post
  4. #3
    Jan 2015
    Simi Valley, CA
    1,783
    From my experience... Once a vehicle has any kind of road film on it, it will then need some type of mechanical intervention, i.e., a conventional wash of some nature, to get it absolutely clean.
    A foam cannon and rinse will remove the "loose" stuff, but the road film will need some mechanical agitation to completely remove it.
  5. Likes jem7sk, DetailZeus, opie, Bruno Soares liked this post
  6. #4
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,374
    Same here except I use a foam gun. As long as the vehicle is LSP’d you can get a perfectly clean car granted the car was only lightly dirty.
  7. Thanks Klasse Act thanked for this post
    Likes Klasse Act, jem7sk liked this post
  8. #5
    Nov 2016
    253
    If you have a spot-free system that could work for a while. Eventually you'll get a film build up on the car. Another option is foam, rinse, then "dry" the car by doing a waterless wash. It should take fewer towels and you wouldn't have to be as careful as if you did a normal waterless wash. Look up the video "15 Minute Car Wash: Water vs No Water" by Larry Kosilla.
    Personally I think the best use for a foam cannon is with a dedicated prewash product to help remove as much abrasive grime as possible before you do a contact wash. An addition to the wash process vs. a replacement for wash process. I don't bother with whole ordeal at this time myself and just do a pressure rinse.
  9. #6
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,226
    Quote Originally Posted by DetailZeus View Post
  10. Likes jem7sk, oneheadlite liked this post
  11. #7
    Feb 2012
    24,529
    After a wash or two a contact wash needs to happen for sureIs it possible to clean with just a foam cannon soak and rinse?
  12. Likes jem7sk, oneheadlite, PaulMys liked this post
  13. #8
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Try Car Pro's Lift, it's a stronger foam than most.
  14. Thanks Klasse Act thanked for this post
  15. #9
    Feb 2012
    24,529
    I have that coming to me sometime in the next week and I am really looking forward to trying it because even though it cost a little bit more if it works the way that I think it works that will be my go to pre washIs it possible to clean with just a foam cannon soak and rinse?
  16. #10
    Sep 2016
    380
    I use Griots Surface Wash, rinse, then Poly-Gloss, rinse. Final rinse with deionized water, then blow-dry and touch up the remaining water. Works fine with mild dirt.
  17. Likes PaulMys, Klasse Act, jem7sk liked this post
  1. Replies: 7
    Last Post: 08-20-2016, 07:56 PM
  2. How to clean your foam cannon
    By hamza7 in forum How to Articles
    Last Post: 08-08-2016, 02:13 PM
  3. Soak car before using foam gun?
    By ymc226 in forum Auto Detailing 101
    Last Post: 06-25-2016, 10:59 PM
  4. Foam cannon, rinse, then wash?
    By ZionsWrath in forum Auto Detailing 101
    Last Post: 08-10-2013, 01:55 PM
  5. How do you clean filthy seats and not soak them?
    Last Post: 05-17-2013, 10:20 PM
