Results 1 to 7 of 7
    May 2014
    Streaking & Spotting With Panel Wipe When I Was Preparing To Put On Ceramic Coating
    So I did a lot of reading & ended up buying Gtechniq CSL & EXOv4 to apply to my car.
    At my best friends body shop, I did the following based on my research:
    1. Washed car
    2. Iron remover
    3. Wash car again
    4. Clay Bar
    5. Polish car
    6. When I applied Gtechniq panel wipe, on the on the car I was getting streaking, & what looked like dried water spots. Did we do something wrong? Temperature was about 10 celcius. Was it because I sprayed the panel wipe directly on to the car? We tried spraying the panel wipe on the towel & I think it was the same issue. We then tried using his usual pre primer/paint spray cleaner. It seemed to go away but I backed out of putting on the coating.
    7. In the end we decided to try (for fun) what he had lying around Chemical Guys Hydro Slick.
    I would like to try again at applying the coating this week.
    What steps do we take from here? Do I need to remove the Chemicals Guys stuff & re polish the car or compound the car (car was re painted last year but we were both so busy, I didn't get around to applying the ceramic coating. Car wasn't driven much at all)
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Re: Streaking & Spotting With Panel Wipe When I Was Preparing To Put On Ceramic Coating
    Best to use panel wipe into the towel instead of spraying onto the panel for this exact issue. And spray away from the paint.
    You will have to polish of that other product in order to prep for the coating.
  3. Likes Loach liked this post
  4. #3
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    How many towels did you use during the wipe off and how big of an area did you do? The spotting and streaking you mentioned... were they only on some panels or is it all panels?
  5. #4
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    To piggy back on what Guz said. Gtechniq panel wipe is quite strong. If your paint is soft or medium-soft, it can cause havoc IME. Chances are you may just need to go over everything with your finishing polish to make sure everything looks good again and to remove the CG’s product.
    Would also look into getting CarPro Eraser or Gyeon prep.
  6. Likes BudgetPlan1, Loach liked this post
  7. #5
    Nov 2018
    77
    Quote Originally Posted by fly07sti View Post
    Why is gtech pw considered strong? It does seem solvent based. I do use nason wax n grease before eraser when coating.
  8. #6
    Super Member Loach's Avatar
    May 2014
    Chicago
    451
    I will echo what the others have cautioned, Gtechniq Panel Wipe is too hot for some paint.
    My test panel that I’ve bombarded with solvents and degreasers and wheel acids galore, it handled a lot of undiluted abuse with no issues, but one direct spray with Panel Wipe immediately causes paint swelling. This swelling subsides once the paint has had time to settle down, but this is not something that you want to see. Same with Duplicolor’s aerosol Prep Spray, this swells the paint worse than Gtechniq.
    Another reason why Klean Strip Prep-All is my go to panel wipe product, no issues on any paint that I’ve used it on so far.
  9. Likes BudgetPlan1, dwaleke liked this post
  10. #7
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    1,999
    Quote Originally Posted by Loach View Post
    That stuff is lubri-liscious! Runs so nice I always follow with Eraser cuz i think something that glides so smooth *must* have some kinda oil in it Streaking & Spotting With Panel Wipe When I Was Preparing To Put On Ceramic Coating
    I went thru a Gtechniq PW phase for a bit, stuff is like pure alcohol; think i still have an unopened bottle cuz i quit using it pretty quickly.
  11. Likes Loach liked this post
  1. Review: 3D Wipe Panel Wipe for Ceramic Coating - 2009 Porsche Carrera S 997.2s
    Last Post: 08-05-2020, 02:21 PM
  2. Newbie preparing for ceramic coating - (CQUARTZ UK 3.0)
    By N8huntsman in forum Auto Detailing 101
    Last Post: 06-05-2020, 03:27 PM
  3. Replies: 6
    Last Post: 04-21-2020, 06:54 AM
  4. Replies: 4
    Last Post: 06-25-2017, 07:28 AM
  5. PB Spray and Wipe Streaking
    By FMINUS in forum Auto Detailing 101
    Last Post: 07-11-2007, 08:11 AM
