Re: Help Correcting 14 Navigator in Tuxedo Black
Or would the Hyper polish be the finest? Also, I’ve heard it doesn’t last long and I’ve had it for 2-3 years or more.
I would suggest you do a test spot with medium polish on a light cutting pad to start. Step up or step down on the aggression when appropriate after that. Let the paint tell you what it needs. The paint system can be different within the same model run so its very hard to say one approach would work across the board.
So the Wolf’s on a light polishing pad. I’ll give it a try.
Finally went after it today. Really didn’t see much difference on the door panels with any of the products; they all took out the minimal marring. The B pillars were a different story. I had to go to opt microfiber cutting pads with Meg’s mf compound to get them smooth.
