G8 as my next tool?
Happy Monday!
I'm looking at a way to better polish small areas on vehicles and wondering about the effectiveness of various tools and wondering if the G8 will meet my needs.
I know it will make doing things like the curved areas on A/B/C/D pillars, side mirrors, various small surface design areas, and headlights much easier. However, I'm questioning the ability for the polisher to get into tight areas like the flat surfaces around air intakes below the front bumper. A typical DA polisher doesn't get into those area very well not only because of the size of pad/throw, but also due to the size of the polisher itself. How does the G8 fair in those situations?
Now I have a G15, my HF DA polisher is in semi-retirement and available to use with a 3" backing plate, but I'm not sure it's sized properly for work in small areas like the G8 will be.
I know many will say the Rupes Ibrid is the answer, but for as little use as it will get for me as a hobbyist, I can't justify the cost.
Re: G8 as my next tool?
The G8 does get into a lot tighter spaces than something like the G15 but it won't fit everywhere. If you want to cover all spots by machine you'll still need something like the Rupes ibrid nano. Even the Flex pixie which can do 1" pads has a large body and will not fit very tight spots like the Rupes would. I don't do enough work to justify such an expensive polisher for small areas so I resort to hand/finger polishing those spots.
Thanks. Overall I think it will be a big help with areas I struggle to reach/get/properly polish with any normal polisher and a 5" pad, but it sounds like I'll still have to resort to a few tricky areas by hand.
The G8 was my first tool. As you know I'm a noob. You've probably given me some advice as I recognize your handle.
I loved it so much and it was so easy to use, I immediately bought the G9 so I could for my cars.
I'm really happy with it. It's really stout, very easy to change the backing plate, and it's great for smaller areas and both convex and concave curves.
I've practice a bit with it on my truck, but used it for the first time on my rear fender. Pretty curvy with tight spots.
I taped up the screws and the little runners, and the two inch plate did a great job in those tight spots.
Another great use for the G8 is spot correcting. Let's say you got one water spot or scratch that requires more aggressiveness than the paint around it. It's easier to focus on a smaller area (and remove less paint of the bigger area) and get just the problem spot taken care of. I often tackle those spots with a microfiber cutting pad on the G8 and a compound, then go over the entire panel with foam pad and a polish to finish the job.
There's always this,
Review: Griot's Garage G8 Headlight Sander
The Griot's Garage G8 Headlight Sander
Thanks, Mike. Headlights will be a no-brainer if I get the G8. I've never been all that thrilled when using a 3" backing plate on my electric drill. Sadly I don't have enough cars needing lights done right now to justify the cost alone.
Thanks. My car alone has enough strange curvy areas I can see it being helpful. Glad to hear you found it to have plenty of power.
Great advice! Thanks. I hadn't thought of that, but now that you mention it I can see a random coating high spot would be a similar scenario...not that I'm not dealing with those right now...
Originally Posted by Desertnate
Happy Monday!
Griot is coming out with a 1" forgot the number.
Nate, you can also get an extension with a 2” BP (as seen here on my GG3).
Thanks, AA!
By jrhoops in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 07-16-2017, 10:10 PM
By scoutfai in forum Rotary Buffers
Last Post: 12-05-2016, 09:10 AM
By pony420s in forum Auto Detailing Tools and Accessories
Last Post: 01-06-2015, 07:07 PM
By juguina in forum Off-Topic
Last Post: 08-11-2012, 08:24 PM
By former86camaro in forum Auto Detailing Tools and Accessories
Last Post: 04-26-2008, 10:27 AM
