Results 1 to 5 of 5
    Apr 2011
    Steamers...upgraded wand, upgraded hose? NO SPITTING??
    STEAMERS...are there any steamers that don't spit water, especially between uses when allowed to sit. I know the steam cools while sitting in hose but is there better/more insulated hoses. Is there any type of wand that diverts water or only allow steam vaper? I have a Karcher sc3 unit and would buy a better hose and/or better wand. Anyone got any advise?
  2. Likes DETAILROOKIE liked this post
  3. #2
    Super Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    970
    Re: Steamers...upgraded wand, upgraded hose? NO SPITTING??
    I know my steamer, a Vapor Chief 100, spits water if it's not properly maintained. Not sure about your unit, but the boiler of my steamer has a water fill sensor inside the boiler that keeps the boiler from being overfilled. When the unit is not maintained, the sensor becomes covered in scale and allows the boiler to fill with too much water. When this happens, there's not enough room in the boiler for the steam to expand and the steam mixes with the excess water which causes the spitting. Once I get it all cleaned up, it returns to working normally.
  4. #3
    Jan 2018
    IE, SoCal
    970
    Rereading your post, it appears as though you're talking about while using it between long periods of use. Mine doesn't do that but I would guess it's because the Karcher isn't heating it enough and the steam has a lot of water in it.
  5. #4
    Jul 2014
    246
    Quote Originally Posted by djstretch View Post
    Have you changed the mineral cartridge lately? Try also running 2/3 water to 1 part white vinegar in the tank. You can use that mix yonvkwnthe internal parts of the machines while using somewhere on tiles or a bathroom. This should fix it. Also make sure the harness of the water is set correctly per the manual and adjust if needed and alway run it on the more steam setting.
    Sent from my SM-N986U using Tapatalk
  6. #5
    Super Member Mike Hoekstra's Avatar
    May 2020
    Grand Forks, ND
    470
    I own a Chief Steamer 75.
    Owner/Operator Auto Massage LLC - www.automassagellc.com
    Custom painter and commissioned artist - www.spikedairstudio.com
  1. Sale has been upgraded to 25%
    By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 08-31-2018, 10:12 AM
  2. For those who have upgraded to the BOSS
    By carguy2007 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 11-22-2017, 05:41 PM
  3. Upgraded Equipment
    By StrmChzr in forum Boat & Marine Craft Detailing
    Last Post: 05-15-2017, 10:05 AM
  4. Griot's 3" upgraded?
    Last Post: 03-23-2016, 05:10 PM
  5. Replies: 15
    Last Post: 08-04-2009, 07:38 AM
