Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Junior Member MattN03's Avatar
    May 2006
    Black & tan trim restoration
    I'm attempting to restore the exterior trim on my 2008 F250. I removed the cowl last night and applied Wolfgang exterior trim sealant. It looked great last night after I reinstalled the cowl panels on the truck. When I came out to the shop today, the panels looked like I had never applied the Wolfgang trim sealant. Is this to be expected? Am I using the wrong product? I also need to restore the tan trim on the truck so I thought the Wolfgang would work well because it would work with black or tan.
    Attached Thumbnails Attached Thumbnails Black & tan trim restoration-20210225_174202-jpg   Black & tan trim restoration-20210225_175929-jpg
    Nov 2015
    Los Angeles, California
    13,659
    Quote Originally Posted by MattN03 View Post
    And that’s exactly why I think it’s among the most overrated products I’ve ever tried... I’m probably the only person who gives it a big thumbs down.
    My suggestion for you would be to try Mothers Heavy Duty Trim Cleaner. If it’s the type of plastic that’s porus and plays well with that cleaner it can work a near miracle. Good luck.
    Mothers Back to Black Heavy Duty Trim Cleaner, best car wax remover plastic trim
    Super Member Rsurfer's Avatar
    Jan 2007
    14,085
    Re: Black & tan trim restoration
    Did you clean it well before applying WETS? If not do as Eldo recommend and clean with Mothers and wipe with IPA and then apply WETS. This should give you at least 6 months of protection.
    If after cleaning, the black or grey seem dull, I would recommend Solution Finish topped with WETS.
  4. Likes Goonie75 liked this post
  5. #4
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,769
    The WG trim sealant (WETS) is not for restoration of severely neglected trim. It is a maintenance product for well-kept trim.
    Get the trim clean. IPA or trim cleaner like Ric said above. Then try Solution Finish. More than one application may be needed.
  6. #5
    May 2006
    Please forgive this novice, but what is IPA?
  7. #6
    Sep 2020
    Eastern PA
    1,747
    isopropyl alcohol (or overly hoppy beer)
  8. #7
    May 2006
    Quote Originally Posted by MisterSnoop View Post
  9. #8
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Solution Finish would be my choice to restore the trim once clean and prepped. Then you can top it with WETS.
  10. Likes fly07sti, DFB liked this post
  11. #9
    Regular Member Epilogts's Avatar
    Jan 2020
    Boulder, CO
    168
    No such thing.
  12. #10
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    I agree with everyone else on using the Solution Finish. Unfortunately, that will only work for your black trim (although they also make a gray version).
    For your tan trim, there isn't a color-specific product like Solution Finish, so you might try this :
    Gtechniq C4 Permanent Trim Restorer, rubber trim sealant, trim restorers, gtech c4
  13. Likes fly07sti liked this post
  1. Replies: 10
    Last Post: 09-18-2016, 05:23 PM
  2. Black plastic trim (now white) restoration - any tips?
    By nyjetfan in forum Ask your detailing questions!
    Last Post: 05-03-2015, 08:48 AM
  3. Replies: 104
    Last Post: 12-03-2014, 08:30 PM
  4. BEST smooth black trim restorer and best restoration method??
    By pointillistic_practitioner in forum Auto Detailing 101
    Last Post: 06-08-2012, 12:53 PM
  5. Black plastic trim restoration (bumpers, mirror housing, etc)
    By sportscarhiatus in forum Auto Detailing 101
    Last Post: 05-14-2012, 10:20 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
