Results 1 to 9 of 9
    Feb 2011
    72
    Door panel problem
    I recently got a 2017 Jeep Grand Cherokee. Most of the vehicle is in good condition except for this area on the driver's door panel. The area is dull and has a brownish tint. Any suggestions to restore this area?
    Attached Thumbnails Attached Thumbnails Door panel problem-0220211922-jpg
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Door panel problem
    Wish I could help but I have no clue what I'm looking at in that picture.
    Feb 2011
    72
    It's the driver's door panel. The problem area is around the memory switch in the middle of the picture.
    Mar 2018
    Conroe, Texas
    477
    I would try an APC cleaner on a MF cloth and scrub. Next step if no impact would be to use a light brush (think toothbrush) and use the same APC or try interior cleaner (enzyme cleaner). Just wet the brush and scrub.
    This method is minimize pushing any liquid into that switch zone.
    It is going to be a slow process to try and fit the product to the stain. Dark plastic normally will not turn brown.
    Sep 2015
    2,171
    is that plastic? SEM makes trim paint......will look brand new again
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    If you are talking about the dulling on the trim ring around the switch button, I agree that trim paint is probably the best solution. If you see brown, the area may be worn down far enough to expose the substrate color of the plastic. Another option is maybe you could replace that trim ring (looks like a block " O " ) for cheap ? Probably pops right out with the right pry tool.
    Aug 2013
    St Louis metro (Illinois)
    5,780
    Is that on the armrest? Looks like the top layer of the surface is wearing off and starting to discolor.
    Feb 2011
    72
    Update: I cleaned the panel with Meguiar's Interior detailer. I think it may have just been dirty and missed by the dealer when they cleaned the car for delivery. I appreciated the replies.
    Aug 2013
    5,780
    Glad you cleared it up. It is amazing what years of grime on certain interior surfaces will look/feel like and lead us to make wrong assumptions.
    When I purchased my current car a couple years ago, I was pretty sure my leather steering wheel was starting to show signs of wear despite the car only being three years old. There were areas which looked like the top coated layer was worn off.
    Long story short, after repeated cleanings and proper care of the leather, the wheel looks brand new and no signs of wear at all.
  1. Clean inside door panel.
    By E93to in forum Auto Detailing 101
    Last Post: 06-16-2018, 09:30 PM
  2. Light door panel scratch
    By mcmanus in forum Auto Detailing 101
    Last Post: 06-01-2015, 12:51 AM
  3. Inside door panel
    By ckosiek in forum Ask your detailing questions!
    Last Post: 12-08-2013, 12:09 PM
  4. Cleaning the felt between door and door panel?
    By nissenc1337 in forum Auto Detailing 101
    Last Post: 04-01-2013, 05:08 PM
  5. Door Panel Cleaning
    By StiCy in forum Auto Detailing 101
    Last Post: 06-08-2009, 04:56 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
