Results 11 to 20 of 37
    Mar 2011
    PA
    5,792
    Re: cleaner for undercarriage
    Figured they were out of business? Tried to contact them awhile back. No response. I just E-mailed them again today. Did not want to place a order and have it in limbo or worse. I'll let you know if i hear anything...
    2018 Colorado ZR2
    Aug 2015
    Andover, MN
    1,727
    Quote Originally Posted by pro 4x View Post
    Looks like if you google "undercarriage pressure washer" or "Pressure washer water broom" there are definitely options out there. A little more money than the Underwasher, but also a bit more robust looking. Ride height can definitely be a factor with some of them (for us non-truck folks. )
  3. #13
    Mar 2011
    PA
    5,792
    No doubt. PLENTY of options for pressure washers.
    2018 Colorado ZR2
  4. #14
    Mar 2011
    PA
    5,792
    Alrighty then. Just got a response from them. The units are indeed current and for sale. I must have used a bad contact E-mail when i first tried to contact them about a month ago.
    Going to have to look them over again this weekend and order one. I am thinking the LONG version would fit my needs.
    2018 Colorado ZR2
  5. #15
    May 2017
    Pittsburgh PA
    2,847
    Ive also been in touch with them since yesterday. So I think it’s legit.
  6. #16
    May 2013
    TN
    1,768
    I received the Ryobi water broom as a present but haven’t had a chance to use it yet. Will definitely be using it after this spring due to the winter salt. Plan to spray a couple APCs and rinse well between each.
  7. #17
    Aug 2015
    Andover, MN
    1,727
    I just realized the underwasher is just for hooking up to your hose, not a pressure washer.
    Not to be a negative nancy, but boy it seems like you could make something like this yourself with some PVC pipe, cement, and a hose fitting. Start with small holes and work your way up to find the right spray pattern. I guess at least they're not charging a ton of money for it.
  8. #18
    Newbie Member Lone Wolf's Avatar
    Mar 2016
    I was looking at the attachments for a PW but I only have a 1.2 GPM 1700.
  9. #19
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    Quote Originally Posted by oneheadlite View Post
    Then get yourself some of the same Salt-Away product to use with it.
  10. #20
    May 2017
    Pittsburgh PA
    2,847
    Quote Originally Posted by 57Rambler View Post
    The price of the Salt-Away kit isn’t bad when searching for the chemical and mixer externally... shipping pushes it slightly higher but I was trying to get them to do combined shipping.
    I have no problem putting down $20-65 for a professionally built product versus pissing my wife off hiding in the garage cutting and sealing PVC that will probably start leaking after 7 uses.
  1. Wheel well/undercarriage cleaner?
    Last Post: 08-18-2016, 09:46 AM
  2. Undercarriage Rust Cleaner?
    Last Post: 08-13-2016, 06:08 PM
  3. Dash cleaner/undercarriage/ drying towels
    By buddy01 in forum Auto Detailing 101
    Last Post: 05-04-2016, 05:38 PM
  4. Undercarriage ??
    By oejeffrey in forum Auto Detailing 101
    Last Post: 10-17-2013, 12:43 AM
  5. What's a good undercarriage cleaner?
    By YankeeFan in forum Auto Detailing 101
    Last Post: 12-22-2008, 05:32 PM
