Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
  1. #41
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Flex vs. Rupes Gear Driven Orbital Polishers
    Quote Originally Posted by 98CayenneTA View Post
    2Black1s.....I was on the fence also between the two gear driven polishers. Also a massive rotary fan with most my finishing using a free spinning da.
    When ya made this thread it could not have been any more perfect timing but.......I went the other way and got the FLEX 10-8 125 somewhat locally.
    I'm seriously impressed with the quality and honestly it is a whole hell of a lot smoother and quieter than I was expecting !
    Thank you for the thread start 2Black1s and everyone who contributed.
    Good Luck with the new Flex. I'm sure it's a great polisher as I've previously stated and most everyone that has one loves it.
    The main reason that I never bought a Flex in the past is the CCW rotation. I won't go into my reasoning all over again as it's previously stated in this thread and others but the CW rotation of the Mille was the single-most determinant factor for me. And then there is the additional bonus to me of the shorter orbit which is a benefit near edges and should "theoretically" produce a finer finish. Again, sheer correction ability was not my goal. Final polishing and finishing abilities are more important to me as those will be the intended primary tasks for this polisher.
  2. #42
    Oct 2013
    I think you would have been happier with the CBeast then. The whole CW point is just moot, when you polish, theyll be equal movement in your passes so I dont understand, why that would be a problem? Also pad grab(bite) is worse on the Mille
    The Rupes is smoother than the Original 3401 but I think the XCE is even better. The Mille is heavier and bulkier so on doors and vertical panels, its not as comfortable in the long run.
    The 5mm is a better for edgework, but the 8mm can work as well.
    Both awesome tools still.
  3. #43
    Apr 2015
    PGH, PA
    1,482
    I've owned all 4
    Makita PO5000C (most RPM)has most correction power and smoothest when paired with correct pad weights
    Only one that can turn into a 3in...griot 3in HD are with force pad or HDO to retain balance.
    If mille(most OPM) was more heavy duty its be second.
    Its also picky on pad weights
    Mille is only one that spins clockwise..
    Flex 3401 (most throw)only due to its longevity/durability
    Flex XCE is a smoother more ergonomic 3401,. but sadly its underspec'd motor wise compare to the OG 3401..it also obtained the flaw of the xfe14 3 point backingplate system...
    Ona side note, my 3in forced mini works well and will compliment any forced machine
    Has 5mm throw like mille, but can't find RPM specs listed anywhere
  4. #44
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    The finisher has pathetic power- have to keep the speed up all the way or it stalls 85% of the time, probably gonna sell one of the two I have
  5. Likes dgage liked this post
  6. #45
    May 2013
    TN
    1,768
    Quote Originally Posted by luckydawg View Post
    I agree. Love the CBeast and PiXiE but the Finisher is a let down.
  7. Likes luckydawg liked this post
  8. #46
    Jan 2016
    1,117
    Its a nice well built machine ergonomic wise-- just has no power
    Hard to believe they still make them or sell any
  9. Likes dgage liked this post
  10. #47
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    665
    Quote Originally Posted by dgage View Post
    I agree. I wanted cordless but with a 3401 already, I added a Finisher with my Pixie. I missed the “forced rotation”. I added a Cbeast and have cordless bliss!
  11. Likes dgage liked this post
  12. #48
    Super Member goldendodo19's Avatar
    Jul 2013
    638
    I’ve loved my rupes 15 for years but recently grabbed a cbeast due to wanting to be free of a cord.
    My first run in with a 3401 years ago made me think I’d never enjoy the cbeast. I picked it up and ran with it, couldn’t even feel the difference between that and the 15 i had been using other than it literally never stalling on any curved panel.
    I was able to basically do the hood and one side of my truck on one battery and it was still on 1 bar then the roof and other half with the second battery. Granted this was not heavy correction just a light polish prior to coating but still.
    Overall if one was in the market I’d strongly recommend the cbeast.
  13. Likes dgage liked this post
  14. #49
    Jan 2016
    1,117
    If your detailing at home or in a shop, i like the uninterrupted power of corded tools. If I am doing a quick job I grab my cordless power tools, If I am going to be using it on a big job, I use corded tools ( drills etc..)
  1. Replies: 31
    Last Post: 04-24-2024, 10:09 PM
  2. Replies: 68
    Last Post: 08-24-2022, 05:02 AM
  3. All brawl with ZERO stall - FLEX Gear-Driven Polishers!
    By Mike Phillips in forum Flex Polishers
    Last Post: 03-24-2022, 09:06 PM
  4. LIVE Detailing Class - Gear-Driven Orbital Polishers - Once Step Detailing
    Last Post: 04-15-2021, 03:44 PM
  5. I never liked gear driven polishers.
    By Joe@Superior Shine in forum RUPES BigFoot Oribital Polishers
    Last Post: 02-19-2021, 07:00 PM
