Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    May 2013
    351
    Re: Ceiling light As Seen On TV
    Quote Originally Posted by BSoares View Post
    I connected mine to the outlets on the ceiling that the garage door opener connects to.
    If you don’t have one there, there are adapters that can give you an outlet from the socket you have on the ceiling.
    These lights we’re talking about daisy chain and power each other so you only need one outlet.
    Will I need them just spaced out the ceiling and not necessarily on the side walls for vertical panels?
    Mar 2017
    Southeastern PA
    2,480
    Quote Originally Posted by bcgreen View Post
    Will I need them just spaced out the ceiling and not necessarily on the side walls at door level?
    Correct. For closer inspection when working on the car I use a Scangrip Multimatch R.
    Bruno Soares
  3. #13
    Super Member Pats300zx's Avatar
    Mar 2006
    Middletown, Del
    5,297
    I actually bought two to supplement the lightning in my garage. I actually found them to be "too bright" and left the entire garage with a washed out look.
    Only Z Best Detailing-Automotive Concours Detailing Services
    http://ozbdetailing.com
    https://www.facebook.com/ozbautodetailing
  4. #14
    Aug 2013
    St Louis metro (Illinois)
    5,809
    I don't think any overhead light would be very adequate in helping with horizontal or vertical surfaces.
    A while back I upgraded the lighting in my garage with multiple overhead LED bar lights. It floods the garage with fairly bright very even light. It is good for coating or LSP application, but when I'm correcting, I'll turn all that off and use lights on a stand which shine light at a low angle across any panel, whether horizontal or vertical.
  1. Clean interior ceiling?
    Last Post: 04-03-2018, 07:56 AM
  2. 4-bulb fixture that plugs into ceiling outlet?
    By dba2 in forum Auto and Garage Accessories
    Last Post: 03-07-2018, 04:20 AM
  3. Ceiling fan wired and hung.
    By Jeremy1976 in forum Auto and Garage Accessories
    Last Post: 07-07-2017, 08:22 AM
  4. Replies: 9
    Last Post: 03-01-2012, 11:00 AM
  5. Cleaning the interior ceiling (or roof)?
    By mcpp66 in forum Ask your detailing questions!
    Last Post: 03-30-2010, 07:27 PM
