Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Nov 2020
    How to restore the OEM brake calipers
    My car is almost three years old now and the OEM brake calipers has shown the signs of its ages. It was silver and looks clean but now it looks dull and has built up dirt and brake dust. After a bit of research I found out that my brake calipers seems to be made of cast iron with zinc plating. Last week I tried clean them with meguiar 's ultimate wheel cleaner and Gold class shampoo with a detail brush. It did help remove most of brake dust and dirt, however the finish still looks dull. what is worse that I found out today the calipers surface has turn yellow a bit. Here is the image. Is it related to the product I used to clean them? What is the best way to restore the finish of brake calipers? For comparison, here is a picture of the brake caliper when it is one year old.
    Regular Member Epilogts's Avatar
    Jan 2020
    Boulder, CO
    168
    Re: How to restore the OEM brake calipers
    My suggestion would be to clean well, and (re)paint with a high quality(high-temp) caliper paint. Prep is important, clean well(chemical and mechanical brush), dry well, tape off all the seals and remove the pads, paint High Temp ceramic caliper specific paint. Otherwise that's just how calipers will look once they get older and heat cycled.
    Jan 2015
    Simi Valley, CA
    1,783
    I think what you are seeing is tarnishing, corrosion and oxidizing of the original plating. I don't think it has anything to do with the products you used to clean them, rather it's just normal aging of a typically driven vehicle.
    The only way that condition could have been prevented would have been through regular and thorough cleanings from the time it was new.
    It looks like you have the calipers as clean as they can be at this point and that's the best you're going to be able to achieve without re-plating or re-coating.
    Jul 2014
    246
    Clean, prep, paint is all you can do and once done you can protect them like any other painted surface. They still look new to me from the picture.
    Sent from my SM-N986U using Tapatalk
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    If you decide to paint those zinc-plated calipers you should bead blast them first to remove the zinc as it will prevent the paint from keying (to the surface).
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    665
    I use Dupli-Color DE1650 Ceramic Cast Coat Aluminum Engine Paint on my Odyssey hubs and caliper. I use 1/4" tape pulled lightly to circle the edge of the rotor to paint the "hats".
    How to restore the OEM brake calipers-img_6422-jpg How to restore the OEM brake calipers-img_6371-jpg How to restore the OEM brake calipers-img_2233-jpg How to restore the OEM brake calipers-img_2231-jpg How to restore the OEM brake calipers-img_4631-jpg
  7. Likes IH8SPM, Azure liked this post
  8. #7
    Jan 2015
    Simi Valley, CA
    1,783
    John U.... Nice!
  9. #8
    Jul 2014
    246
    That looks great and Dupli color has tons of colors to choose from for about $8 a can. If anyone is planning on doing this I suggest getting ultra thin plastic drop cloths to cover your car unless your removing the calipers and bracket. Great work once again.
  10. #9
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Could always invest in the G2 caliper kit which holds up better than the rattle can caliper paint.
  11. Likes BudgetPlan1 liked this post
  12. #10
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,000
    That held up nicely for nearly 15 years, 60k miles on the '04 Vette. No snow or salt but otherwise good stuff.
  13. Likes The Guz liked this post
  1. Wheels and brake calipers
    By Teddyp in forum Hot topics & Frequently Asked Questions
    Last Post: 08-25-2016, 07:40 PM
  2. Brake calipers... Wasted wax?
    By brettS4 in forum Auto Detailing 101
    Last Post: 09-23-2015, 09:23 AM
  3. Brake Calipers
    By havasu486 in forum Auto Detailing 101
    Last Post: 03-24-2015, 07:38 AM
  4. Which color brake calipers
    By goldendodo19 in forum Off-Topic
    Last Post: 02-19-2014, 12:33 PM
  5. Painting brake calipers
    By S2K in forum Auto Detailing 101
    Last Post: 05-08-2011, 08:03 AM
