TW Flex Wax drying aid?
Any thoughts on what to use? Thought about A certain companies graphene detailer, but interested in the thoughts of others. Thanks!
Re: TW Flex Wax drying aid?
If you wanna stay graphene Adam’s graphene detail spray. If you don’t care (I don’tvthink it matters much) and want to stay with TW, Hybrid Solutions Wet Wax
TW Flex Wax itself can be used as a drying aid. I would just stick with the Flex Wax.
THIS. Right from the directions...
The third possible way is the one-step version that is the biggest time saver. Simply apply wet and then dry.
After you have a good base of it on, use it that way to maintain/refresh the finish as needed.
Thanks. I just like to use something while drying. I have the wet wax but wasn’t sure on compatibility. Maybe I’ll try a graphene detail spray.
Since the TW Flex Wax is designed to be used as a drying aid (among the several different ways it is designed to be used), is there a particular reason why you do not want to use the TW Flex Wax as a drying aid? If you are looking for a drying aid that is compatible with Flex Wax, I don't think you can get much more compatible than the Flex Wax itself.
Really just the cost. I wash often in the summer and weekly washes will get expensive with flex wax as a drying aid. I’ve considered diluting it for a drying aid and maybe using it full strength every couple of months. Off label, I know.
Really just the cost. I wash often in the summer and weekly washes will get expensive with flex wax as a drying aid. I’ve considered diluting it for a drying aid and maybe using it full strength every couple of months. Off label, I know. ��
Ah, that makes sense. One of my favorite, more cost effective drying aids is Meguiars D156. I haven't tried it on top of Flex Wax, but I would be curious if that would work.
That said, I would also be curious if you used Flex Wax as a drying aid and only used one spray per panel, how long would a bottle of Flex Wax last?
By Route246 in forum Auto Detailing 101
Last Post: 05-12-2018, 09:09 PM
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 09-17-2016, 03:22 AM
By octane in forum Auto Detailing 101
Last Post: 11-12-2012, 04:26 PM
By MichaelD in forum Boat & Marine Craft Detailing
Last Post: 10-16-2012, 01:28 AM
By Tank_McNamara in forum Auto Detailing 101
Last Post: 05-30-2010, 10:47 PM
