Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Sep 2015
    2,173
    Coating single stage paint - should you?
    I saw a post on a FB detailing group, where the poster said that he did a ceramic coating on single stage paint. Is this something you can/should do? I thought I'd remembered reading that you shouldn't.
    Re: Coating single stage paint - should you?
    New or modern single stage paint or old school single stage paint.
    Sep 2015
    2,173
    I guess I would call it new....looked to be on an early 2000's Chevy Truck
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,897
    New/modern day SS paint is good to go. You can run into 'streaking/patchy/blotchy' spots on some older/old school SS paint in my experience.
    Scott Harle
    Autodermatology
    #autodermatology
  5. Likes The Guz, TTQ B4U, firecorgi liked this post
  6. #5
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Quote Originally Posted by Sizzle Chest View Post
    Look no further for an answer.
  7. #6
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    honestly on a 2000 truck like that, I would be more inclined to play with some megs #7, then polish it up and lay on nice quality sealant or a wax. it's not often I turn down coatings but on single stage I've seen paints respond very well to other products and it almost is a bit nostalgic to use non coating products.
    2023
  8. #7
    Sep 2015
    2,173
    Thanks everyone for your replies
  9. #8
    Super Member Craig Encinitas's Avatar
    Jul 2020
    312
    From what I’ve found, Brian at Apex Detail mentioned (not demonstrated) using an acrylic polish, Xtreme Solutions LVR 403 or 404 and letting that cure 24-48 hours, that you could ceramic coat single stage paint.
    I have a client who wants this done on an ‘84 Mercedes Benz. A conversation will be had, as I think some people might assume that a ceramic coating is permanent. After it wears down, what then? Polishing off the coating and back into the single stage paint on an old car...that’s out of my experience range.
  10. #9
    Here's the actual deal...
    If the coating you use requires you to use a panel wipe (solvent) to chemically strip the paint before applying the coating, with OLD single stage paint like solvent-evaporation lacquers and enamels - the act of chemically stripping this type of paint with a solvent can DULL the paint down.
    If it's NEW old school type paint or NEW modern URETHANE single stage paint - no problems.
    This question comes up from time to time. The first thing I do is what I did? Ask the TYPE of paint you're working on.
    Condition is a factor too with old school paints. There's a difference between the ORIGINAL dried out paint on a 1952 Chevy and the single stage paint on a 1952 Chevy that was REPAINTED in 1978 and then maintained.
    Clear as cloudy clearcoat?
  11. Thanks Craig Encinitas thanked for this post
    Likes PaulMys, seanktm, firecorgi liked this post
  12. #10
    Here's a coating detail did to a MODERN single stage URETHANE paint job 8 years ago.
    Detailer’s Paint Coating on Single Stage Paint
  13. Thanks Craig Encinitas, firecorgi thanked for this post
  1. Ceramic Coating on single stage paint
    By mtrisnohadi in forum Ask your detailing questions!
    Last Post: 06-01-2019, 08:09 AM
  2. Coating Single Stage Paint
    By xabo in forum Ask your detailing questions!
    Last Post: 11-29-2017, 06:05 PM
  3. Ceramic Coating a Single Stage Paint.
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 09-28-2016, 07:05 AM
  4. Pbl paint coating on single stage?
    By sunshine sc in forum Auto Detailing 101
    Last Post: 11-20-2015, 02:48 PM
  5. Pinnacle Black Label Coating and Single Stage Paint?
    By tiSS'er in forum Auto Detailing 101
    Last Post: 05-23-2014, 11:03 AM
