Results 1 to 5 of 5
    Dec 2020
    Detail Product ?s
    I have been using the following but always looking to see what others are using for products..... Any Compund/polishes that might work better in any of the 3 stages below?:
    I have the following...
    Griot's Garage 6 Inch Random Orbital Polish
    5 Inch D.A. Hook & Loop Flexible Backing
    Compound Step
    Orange pad 5.5 inch Lake Country ThinPro Foam Pad or Hybrid Wool Cutting Pad w/ Carpro Clear Cut
    Polish Step
    White 5.5 inch Lake Country ThinPro Foam Pad w/ Meguiar's Mirror Glaze Ultra Finishing Polish M205
    Wax/Coat/Seal
    Red 5.5 inch Lake Country ThinPro Foam Pad w/ Jescar Power Lock Polymer Paint
    Looking for shine, pop, durabliity, longevity since both cars sit outdoors now. One is a metallic blue and the other flat white.
  2. Likes Craig Encinitas liked this post
  3. #2
    Re: Detail Product ?s
    If you're NOT going to use a coating - then BLACKFIRE One Step.
    I actually will use it like a compound, (aggressive pad and rotary buffer), just because it wipes off so easy.
    But it does contain a sealant so it's the wrong type of product to use if you're going to use any type of paint coating due to it leaving sealant behind.
    I haven't used the CarPro Clear Cut? I do like the Pinnacle Advanced Compound - works great on everything. Also the 3D One.
  4. #3
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    For compounds...Sonax Cutmax, Menzerna 400 are amazing. 3d ACA 500 if by rotary.
    Finishing....Sonax Perfect Finish, Menzerna 3500, Carpro Essence
    Carpro Clear Cut is also a VERY good cutting compound.
    Ripping through your mind like a hurricane full of novocaine
  5. #4
    Super Member Dan Tran's Avatar
    Sep 2015
    Portsmouth, NH
    1,055
    Detail Product ?s
    Quite honestly, I think that you all ready have a good combo of products. I have personally used everything you have. All great products. M205 is highly versatile and Clearcut is quite magical on its own.
    I personally now use Meguiar’s Microfiber Cutting Disc with Jescar Correcting Compound and RUPES yellow foam pad with Sonax Perfect Finish.
    But it doesn’t mean that you can’t achieve the same results with what you have. M205 is a classic.
    If I had to add anything to the mix, I am a RUPES yellow wool pad and RUPES UNO Protect kind of guy in terms of all-in-one applications. Excellent slickness in my opinion.
  6. #5
    Dec 2020
    Thanks for the input!
  1. Cost of product per a detail
    By SSStang in forum How to make money detailing cars
    Last Post: 01-01-2015, 12:16 PM
  2. First Detail - Product List
    By Wors in forum Auto Detailing 101
    Last Post: 06-16-2012, 04:57 PM
  3. The One Product You Couldn't Detail Without
    By DLB in forum Auto Detailing 101
    Last Post: 10-14-2009, 07:20 AM
  4. Detail Product Bag?
    By Hades02 in forum Auto Detailing Tools and Accessories
    Last Post: 09-07-2009, 11:21 AM
  5. Corolla Detail- post winter + new product detail
    By budman3 in forum Show N' Shine
    Last Post: 05-18-2008, 08:38 PM
