Results 11 to 20 of 23
    Super Member TMQ's Avatar
    Mar 2015
    Germantown, Md
    2,243
    Re: Riot, sorry protest, damaged fj cruiser. Spray paint removal
    Paint reducer----get it from a body shop. Safer than thinner....
    Slow to remove---Keep at it.
    tom
    Mr Tommy's
    Wash, Buff, Wax
    Website: mrtommyshine.com
    May 2017
    Pittsburgh PA
    2,847
    Sorry that happened to your vehicle! Not very peaceful at all.
  3. #13
    Sep 2020
    57
    You mean you DONT want to drive around with "f*ck police" painted on the side of your car?! Good luck with the removal, I'd have lost my mind if that happened to any of my cars which is partially why I've avoided downtown Portland for several months!
  4. #14
    Dec 2018
    7,157
    Quote Originally Posted by joshhas99problems View Post
    You guys missed it. He bought it like that from an auction.
    If you can get a perfectly good car with paint damage for totalled price it’s a steel. If it doesn’t come off you can always wrap it or plasti dip it.
  5. #15
    May 2017
    Pittsburgh PA
    2,847
    I did miss that. I’m sorry for whoever used to own that car then. Or for the insurance company or whoever got dealt the worst from terrible behavior.
  6. #16
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by lj993 View Post
    I have a 2007 FJ Cruiser. It was vandalized by some peaceful protestors. I need to remove the spray paint graffiti. Spray paint has been on since July/August. I researched liquid carnuba. It slightly cut the spray paint, but requires way too much work. Paint has probably been sitting too long.
    Lacquer thinner should pull it off okay. Not knowing the history of the panels and work done, just do a small test spot first. If it's factory, you'll be fine.
    2023
  7. #17
    Keep us updated please.
    I'm sure the methods and product you end up using will help others into the future.
  8. #18
    Mar 2014
    La Jolla, Calif.
    239
    the FJ Cruiser arrived late this afternoon. The big rig had to drop it about a mile from the house due to tight roads/turns. I had three people come up and ask me what happened to it as I was settling up with the delivery driver. It was out of gas, so I kept my fingers crossed on the drive up the hill. Got home and pulled out the Flex 3401 and some Lake Country Orange Pads, some Rupes Blue Pads and some Rupes Uno Pads. I pulled out my gallon jug of Optimum Compound, only to find that it was dried out! Thankfully there was only about 1/3 of the bottle left. I used the Rupes Blue Course for most of the truck. I started with the Orange pads with the Rupes Blue, it did a pretty good job of removing the paint, patience, patience, patience. Not super quick, but the paint did come off. Problem was that the Orange pads got clogged very quickly. I went through 14 pads. I switched over to a Rupes blue pad with the Rupes Blue Course chemical. It worked really well. As I loaded the pads with chemical, the paint came off pretty quickly, for a few minutes. As the chemical seeped into the pad, the cut slowed down. I was using four or five, grapes sized drops of chemical for each pad reload. I also used four Rupes Uno pads. They worked well, as did the Rupes Blue pads. The stiffer pads worked better than the Lake Country Orange pads. There were some thicker spray paint spots that just didn't want to come off. I pulled out some 2500 grit wet sanding paper. I lightly worked on the thicker spots with the wet sanding paper. It worked really well. I was concerned with taking off too much of the clear, so I tried to limit the wet sanding paper to the actual spray painted spots, the best that I could. I stared on the FJ Cruiser around 6 pm and finished up around 9:15 pm. I called it a day out of concern for my neighbors. The Flex isn't as quiet as the Rupes. I was already a bit embarrassed driving the truck into my neighborhood with the offensive language painted on the side. I spent another 30 minutes cleaning out the interior, lots of broken glass chips, dust and fast food wrapper shoved under the seats.......had a few raccoon footprints on the seats too. They must have come through the broken rear quarter glass......I also did a quick wipe down of the engine compartment, lots of Utah and Idaho dirt and dust........Somebody had some fun with this FJ Cruiser!
    The paint on the truck is surprisingly smooth. I intend on doing a full detail once I get the windshield and rear quarter glass replaced, but when I washed it prior to starting on the spray paint, the hood and top felt as if they had been recently clayed. Keep in mind that this truck has been sitting outside at an auction lot in Utah since August. Lots of sun, heat and recently snow.
    The Toyota has really nice silver paint, with a white top. It should look pretty nice when it is all polished out. I am really please with the progress so far. (although I am not looking forward to cleaning 14 pads tomorrow........) The panels where the paint was look great. I will need to follow up with some Rupers Yellow or White to get the full gloss. I will probably top it off with Some HD Speed or some Black Fire One Step.
    The suggestions for the various liquids are greatly appreciated. The truck arrived after most local shops and stores were closed for the evening and I wanted to get the spray paint off asap. They probably would have cut the cleaning process down to 30 minutes. I will add some photos from tonight and add some better ones in the daylight tomorrow. All the best. Glad to see the Autogeek pre-Black Friday sale kicking off. I need some chemicals and want to finally pull the trigger on the 303 Graphene Spray.
  9. #19
    Mar 2014
    La Jolla, Calif.
    239
    Here's some pictures
    Riot, sorry protest, damaged fj cruiser.  Spray paint removal-img_0249-jpg
    Riot, sorry protest, damaged fj cruiser.  Spray paint removal-img_0251-jpg
    Riot, sorry protest, damaged fj cruiser.  Spray paint removal-62761749303__d1b660a1-b5fb-43fc-a5a9-26a8d5031f0e-jpg
    Riot, sorry protest, damaged fj cruiser.  Spray paint removal-62761862109__c0fa8efb-51c7-4f0e-ad25-99e199342058-jpg
    Riot, sorry protest, damaged fj cruiser.  Spray paint removal-img_0257-jpg
  10. Likes Icarus, Big Dave liked this post
  11. #20
    May 2017
    Pittsburgh PA
    2,847
    Awesome, it’s impressive you removed that slop in a timely fashion and that the paint otherwise seems nice. No time to even let it sit out... drive it up the hill and get to work, lol.
    I’m sure that vehicle (if it has a mind of its own) knows it is in very good hands!
  1. Replies: 0
    Last Post: 07-23-2017, 12:41 PM
  2. Replies: 19
    Last Post: 08-18-2015, 12:04 AM
  3. Spray Paint Removal From Plastic Trim?
    By Desertnate in forum Auto Detailing 101
    Last Post: 05-22-2015, 08:33 AM
  4. FJ Cruiser (Paint Correction and Interior)
    By HUMP DIESEL in forum Show N' Shine
    Last Post: 07-21-2014, 12:42 PM
  5. BMW M6 Protest
    By VISITOR in forum Auto Detailing 101
    Last Post: 09-18-2013, 05:58 AM
